BMW 3-Series (E90 E92) Forum
can a lci hood fit on a pre-lci??????
01-25-2013, 01:18 AM | #1 |
Rep 131
Hi all, was checking to see if a lci hood can fit on a pre-lci??? or do you have to buy the bumper to?? if so what vendor is selling the lci hood?.... Thanks...
01-25-2013, 01:44 AM | #2 |
Rep 4,732
Drives: Alpine White '13 550i
Yes it fits..you just need a pair of lci grills and you're good to go. Not sure of specific vendors but they're definitely around you just have to search.
01-26-2013, 12:14 PM | #4 |
Rep 156
If you not replacing the bumper then why one need the Grills ? I thought Grills are part of the front bumper, and Hood goes on the Top..
01-26-2013, 12:15 PM | #5 |
Rep 186
01-26-2013, 12:57 PM | #7 |
Rep 156
01-26-2013, 01:00 PM | #8 |
Rep 156
01-26-2013, 01:44 PM | #9 | |
Rep 186
As for the other statement, I think a 328i could be an E90 or E92. Was just saying that my reply would only be relevant for the E90... E90 lci has the grills in the bumper only. Pre-lci has part of the grills on the hood/bonnet. The pre-lci bonnet can be modded to fit the lci bumper but unfortunately it seems that you cannot mod the lci bonnet to fit the pre-lci bumper. I'm speaking about the standard hood, the M3 hood should be the same though... Hope that clears everything up. |
01-26-2013, 05:45 PM | #10 |
Rep 4,732
01-26-2013, 05:57 PM | #11 | |
Bausman
64
Rep 1,817
never the other way around. And an OEM m3 hood WILL NOT fit non-m bumpers at all because the hood is wider to compensate for m3's wider body than the non-ms |
01-27-2013, 01:09 AM | #12 |
Q(*.*)-D Q-(^.~Q)
214
Rep 5,378
Drives: like an old person.
Hmm I was thinking of just installing LCI hood and grilles on my PRE LCI M3 rep bumper. Should work with some modification. I don't see how it won't work unless the shape/size of the grilles are different between PRE LCI and LCI on the bumper? But I'll talk to my body shop about it. This will be my next project.
01-27-2013, 01:28 AM | #13 | |
Bausman
64
Rep 1,817
01-28-2013, 12:35 PM | #15 |
Rep 2,353
In order to use the LCI hood you will need an LCI bumper and grilles to go with it (I've done a LCI conversion). Save the cash and do it right, otherwise it will look horrible.
Also, the M3 hood is longer, not wider than non M. |
01-28-2013, 05:30 PM | #16 |
Q(*.*)-D Q-(^.~Q)
214
Rep 5,378
Why would the fenders need to be arranged?
Is it necessary to have a LCI bumper? Is it because of the grille fitment? Just curious because other than that I don't see how the bumper would get in that way from installing the hood.
01-28-2013, 05:43 PM | #17 | |
BimmerPost Supporting Vendor
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
Kind of sucks if you ask me.
01-28-2013, 05:48 PM | #18 | |
Rep 2,353
are you referring to the e92??? the LCI E90 is not longer, the only difference are the hood, grills, front bumper and lights ( pre lci lights fit fine, just the internals of the lci lights change). Fenders do not have to be touched for the retrofit. you can change out the fender liners and brake ducts as well if you want, but not necessary. Last edited by ._.; 01-28-2013 at 05:54 PM.. |
01-28-2013, 05:50 PM | #19 |
Rep 2,353
01-28-2013, 06:18 PM | #20 | |
Q(*.*)-D Q-(^.~Q)
214
Rep 5,378
So it comes down to the grilles. Is it bigger or something? I was comparing pictures of a PRE LCI/LCI and the difference to me was the top area of the grilles where it was more rounded on a LCI which shouldn't be a problem since the hood will replaced right? Does my theory make sense? Lol. Hmm maybe I will buy a used LCI grille and do a test fitment on my bumper.
01-28-2013, 06:22 PM | #21 | |
Bausman
64
Rep 1,817
01-28-2013, 11:27 PM | #22 |
Where'd my VTEC go?
481
Rep 6,067
The entire shape of the grilles are different. You might be able to force it to fit, but it will look off.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
