BMW 3-Series (E90 E92) Forum
Euro/US Halogen Comparison
01-21-2013, 05:29 AM | #1 |
Rep 1,311
Ok, so I recently acquired a pair of really nice Euro spec'd halogen headlamps and I'm looking forward to installing these and finally ridding myself of those gawd awful ambers. Thing is, there's a slight difference between the two and I need some questions answered. So, on the US spec'd halogens, the low beams have what I guess is some sort of shroud that goes over the bulb while on the Euro spec'd there is no such device. Would I be wrong if I assumed that the euro is going to emit what appears to be a high beam because it doesn't possess that "shroud" device even on the low beam setting? Kind of seems that way. Are these Euro specs even street legal in the US and if not, how can I make them so? I want these headlamps on my bimmer and want to make every effort to ensure safety for all and legality for myself. No reason to rouse the hogs, you know?
04-21-2013, 09:15 PM | #5 |
I got lei'd
846
Rep 7,594
Nice, for how much? Yes even without AE's they look good. I've been trying to reach out to a forum member that helps get euro lights but hasn't Pm'ed back. Let me know how you got them, I'll try.
04-21-2013, 09:48 PM | #6 |
Rep 1,311
I got em for right around $300 shipped, off a guy on eBay. I cruise eBay a lot and have gotten a shit load of super deals. If you don't have any qualms about shopping there you should go check it out.
04-21-2013, 11:20 PM | #7 |
I got lei'd
846
Rep 7,594
Cool, something I should be doing more often then, didu use US ebay or Israel ebay? I see myself looking in german ebay sometimes
04-22-2013, 02:15 AM | #8 |
Rep 1,311
I mostly just use US eBay, but I have crept over to the UK and even Japan sites too. You never know what they're turning up in their parts of the world. The Israeli dude actually threw his auction up on the US site, that's how I found them. Hmm...eBay Deutschland? Never thought of that, thanks!
04-22-2013, 02:57 AM | #9 |
uber driver
114
Rep 657
About the bulb shield, you'll be fine. High beam just means your light is angled higher than the low beam; not necessarily a power difference between the beams. Without the shield, you will just have slightly more output but it will not blind anyone.
04-22-2013, 05:31 AM | #10 |
Rep 1,311
Finally, someone with an answer, thanks. I was concerned about it at first, but got it all sorted out after talking with my mechanic.
04-22-2013, 12:05 PM | #11 |
Rep 303
Your European headlight (ECE) set has a different reflector for high beam as opposed to low beam. That is why you have four reflectors in total, two high beams and two low beams. The bulbs used are H7 for both and they have a black top similar to your American bulb cap, so no glare, due to the bulb itself. The beam pattern in the European type has a higher beam level towards the right side so that u can read the sign posts on the side of the road (European thing). The American lights (DOT) have a stray light in the middle of the light beam so that you can read over head signs. That unfortunately blinds the other drivers coming from the opposite side. This is some thing that annoyed me during my visit to USA.
Here is the beam patterns explained in detail. Look at the yellow beam patterns on black back ground. By the way you could have bought the LCI head lights (with halogen angel eyes) from Europe for just a little bit more. Here it is from Sweden. Each LCI headlight costs 220Euro. http://www.schmiedmann.se/3_serien/E...r-exterior.htm http://www.danielsternlighting.com/tech/aim/aim.html |
04-22-2013, 12:25 PM | #12 | |
Rep 1,126
04-22-2013, 01:14 PM | #13 |
Rep 160
Drives: Deep Green E90 325i
Interesting.. I got my LCI Halogens straight outta Latvia, and the first thing I noticed is that there was no glare shield on the bulbs, but the bulbs themselves had some sort of built in shield. Didn't really notice any other differences honestly, but my headlights do have that clear beam pattern angled upward to the right.
18" Staggered Style 189 - BMS 15mm - CF Grilles - LCI Headlights - BMW Performance CF Intake - 12" Blaupunkt Subwoofer |
04-22-2013, 01:19 PM | #14 | |
Rep 1,361
04-22-2013, 04:48 PM | #15 |
Rep 1,311
You know, when I first bought this car I asked the dealer themselves about the possibility of upgrading my lights to something with AE's and they basically told me that the process was probably way too uneconomical to even consider because of when my car was built(July '06). That's really why I decided to go with the straight euro halogens. What you suggested above is plug and play for me or do I have to fiddle with my wiring and recode the system to get them to work? You've got me scratching my head again man.
