01-01-2013, 03:35 PM | #1 |
Rep 20
New Suspension install MCS
I just installed a new Motion Control Systems suspension 2-way adjustable with exterior canisters on my 2007. Here is what I ordered from Bimmerworld. I got to talk to James Clay and he helped figure out the spring rates and setup given where I was at. Here is what he came up:
MCS (Motion Control Suspension) Remote-Reservoir Damper Sets Model: E36 3 Series; Adjustments: 2-Way (Coilover Rear*: Yes; Spring size (2.5", 2.25", or 60mm): 2.25"; Size for complimentary T-shirt (S-XXL): See notes) 1 MCS Rear Clevis Mount Set - E30/36/46 4 MCS (Motion Control Suspension) Canister Bracket Kit Ground Control Adjustable Camber/Caster Race Plates Car Model: E46 3 Series; Front Spring Diameter: 2.25" (Shock Brand: MCS (MZ4 car)) 2 Hypercoil 2.25" ID Coilover Springs by Hyperco Select Free Length: 5"; Select Rate (lb/in): 700 2 Hypercoil 2.25" ID Coilover Springs by Hyperco Select Free Length: 7"; Select Rate (lb/in): 425 1 Hyperco 2.25" Helper Spring Set 1 Helper Spring Guide Set - 2.25" 1 Torrington Bearing Kit I cannot say enough good things about James Clay. He spent a lot of time on the phone and thru emails making sure he got me the right system and setup. Thank you James it works amazing!!! Marc Norris at Bavarian Workshop in Canoga Park, CA installed the suspension and did a great job mounting the canisters. Here are the alignment specs that James recommended: Set Front typically 1” to ½” gap above front tire between fender Rear 1/4" higher than front, measured to metal at front and rear jack points on bottom of rocker Front Camber -3.0 deg Front Toe 1/8" out total Rear Camber -1.8 deg Rear Toe 1/8" in total I will put pics in another post.
2007 BMW Z4 MC, Roll Bar, Cobra Race Seats, Motion Control Systems Coil over, Enkei NT03 Wheels, StopTech Trophy BBK. RPI Scoop, ESS s/w more...
01-01-2013, 03:44 PM | #2 |
Rep 20
pics
Here are the pics of the install:
Rear Trunk Close up rear canister Close up rear rebound adj again rear rebound adj at bottom of rear coilover Front trunk (yes it needs to be cleaned last event front two went off) Passenger front (the windshield fluid canister had to come out) Drivers front
01-01-2013, 04:43 PM | #3 |
Rep 11,667
Nice setup....
Did you do any reinforcement of the rear strut tower?
01-02-2013, 11:39 AM | #5 |
Rep 20
Yes I have a roll bar welded into the rear strut tower that is why I went with rear coil over since it is a better setup, at least according to James Clay at Bimmerworld whom knows more than me anyway and my mechanic.
01-02-2013, 11:43 AM | #6 | |
Rep 20
Yes all corner balanced using my weight as driver. The alignment is from James Clay I was running those same number except for toe. I ran a total of 1/16th toe out in front and 1/16th total toe in on the rear but went with the 1/8th numbers James sent.
01-02-2013, 11:49 AM | #7 |
Rep 924
Nice mod but that is the dirtiest Z4M I have ever seen.
FD3S69.50 |
01-02-2013, 01:26 PM | #8 | |
Rep 222
01-02-2013, 01:48 PM | #9 | |
Rep 880
I have similar toe front/rear & front camber setup but I have -2.2 rear camber and 1/4'' lower rear height than front. |
01-02-2013, 01:56 PM | #10 | |
Rep 11,667
I was wondering you changed caster for more dynamic camber.
01-02-2013, 02:08 PM | #11 |
Rep 20
I would love to if I had them. I asked the shop to give me all those numbers but they did not. They were short handed at the time of working on my car so it became a last minute rush to get it to me in time for my event.
01-02-2013, 02:11 PM | #12 | |
Rep 20
Lastly, you went over my head with the dynamic caster comment. I love to drive but still learning about ALL the technical aspects of suspensions and setup.
01-04-2013, 12:32 PM | #13 |
Rep 20
Here is my best lap on new setup:
Here is why the car is so dirty. It was snowing lightly and I got a little over zealous!
01-04-2013, 02:24 PM | #14 |
701
Looks like the conditions were challenging. How hard was it to get heat into the tires?
That turn you spun in--it looks like it had been causing some issues in the laps preceding it in the video, and even in the fastest lap--but you caught the car each time up until that point. Glad it was nothing more serious than some dirt. Is that a tricky corner usually, or was that particular spot just traction challenged due to cold/snow/damp in that section? (I haven't driven that track.) Last edited by Finnegan; 01-04-2013 at 02:44 PM.. |
01-04-2013, 09:10 PM | #15 | |
Rep 20
Normally that turn is easy and a lot of fun. A long sweeper that you simply throttle steer thru. Usually the car pushes out as you apply throttle and you lift to get back in line. Getting oversteer when applying throttle was throwing me off big time that and the cold and snow. Once I sort out the setup that turn will be the easiest and funnest on the track. Lastly my front tires were brand new and the rears had around 8 heat cycles so that also contributed to the issue somewhat I would guess.
01-27-2013, 09:16 PM | #17 | |
Rep 969
Sold 2011.5 E92 M3 ZCP.
05-22-2013, 06:37 PM | #18 |
Rep 505
Bringing this thread back to life. You have had this suspension for some time now and wanted to see how happy you are with the setup you choose...GC race camber/caster plates, spring rates and length specifically. Would you change any components if you had to do it again. I assume your car is still street legal and you drive it to/from track.
05-22-2013, 10:26 PM | #19 | |
Rep 100
Drives: 2006 Z4 3.0si
BTW It's CORNER balancing OP that's a hot setup for sure, I've always been a huge fan of BW and James. He comes out to the 25hrs at THill and turns a wheel for fun, super nice guy. Our touring car has fully boxed rear shock towers and threaded collar dampers.. been toying with going the true coilover route for a while now. Starting over with suspension tuning prevents me from doing it just yet.
05-22-2013, 10:39 PM | #20 |
enthusiast
48
Rep 1,695
I don't think the numbers matter. The reality is that they are never the same. I write them down, but you don't look at them until you are there to corner balance again. And NorCal cyclist can vouge that I have done an insane amount of suspension adjustment and corner balancing yearly.
This is assuming that you trust the shop. |
05-23-2013, 12:50 AM | #21 | |
Rep 100
07-05-2013, 07:23 PM | #22 |
Rep 505
After month of waiting I finally have tracking number. Excited to tackle install next weekend.
Went with similar setup as OP: Dual adj external res MCS GC race camber plates Hypercoil 5" 700/850lb springs and spring helpers Adj front end links GC weight jackers Turner RTAB Clevis mount/RE rear shock reinforcement |
