BMW 3-Series (E90 E92) Forum
spark plug chamber oil leak
08-13-2012, 09:01 PM | #1 |
alpine white
13
Rep 342
So I went to change my spark plugs yesterday and as I was checking the old ones I found that one of the chambers had a bunch of oil in it. I didn't check all of the chambers but I did check most of them and only the second one from the front of the car had a leak. I guess it's just a bad valve cover gasket or spark plug seals so I'm gonna replace those. I was also told that while I'm at it I should replace the bolts that hold down the valve cover. Is that necessary or can I get away with just using the old bolts? They're aluminium bolts if that helps.
thanks |
08-14-2012, 04:24 AM | #3 |
Rep 1,558
I have replaced many valve cover gaskets on BMW's without replacing the bolts, you'll be fine.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
08-14-2012, 09:56 AM | #5 |
hehe ty men
32
Rep 172
I've done 2 VCG's already and I never had to replace the bolts... but that was on my E46. With the newer E90's since they use the new aluminum bolt, it is suggested that you replace it every time.
08-14-2012, 10:21 AM | #7 |
alpine white
13
Rep 342
they're not that expensive so just to be safe I'll replace them. thanks guys.
anyone happen to know if you need to remove the valvetronic motor to get the valve cover off? |
08-14-2012, 10:29 AM | #8 | |
Rep 850
