2010 2011 BMW 5 Series Forum F10 ♦ Sonic MS | Forgestar CF5 Rotary Forged Wheels (New for 2011) |
03-16-2011, 07:33 PM | #1 |
429
Rep 4,650
Sonic Motorsports 1045 West El Camino Real Mountain View, CA 94040 tel: 650-733-6506 fax: 650-691-9009 email: info@sonicms.net Presenting the ultra light, yet affordable one piece rotary forged Forgestar CF5 wheels. These wheels are made to order with custom offsets available, to fit your F10 5er perfectly without the need for spacers or fender adjustments. Rotary Forged / Flow Formed Cast - Technical Information This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction. Click Here to View Test Reports from Independent Third Party Test Labs Recommended Fitment for the F10 5er 20x9 ET35-40 20x10 ET40-45 245/35/20 285/30/20 We also offer full rim and tire packages including OEM TPM sensors. We utilize the Hunter Road Force GSP9700 Balancer and “Touch-less” Auto 34 Mounting Machine to mount and balance your rims and tires safely and effectively, without risking any damage to your new investment. Recommended Tires *Please click on link for more information on the tire, including pricing. Sumitomo HTR Z III Hankook Ventus V12 Yokohama S.drive Bridgestone Potenza RE760 Sport MSRP Pricing: 18 inch - $1600/set 19 inch - $1860/set 20 inch - $2560/set For best pricing and ordering information, please call me at 650.733.6506, email at cal@sonicms.net or shoot me a PM. Last edited by Cal@Sonic MS; 05-18-2011 at 07:31 PM.. |
