BMW 3-Series (E90 E92) Forum
Interesting article on 335i auto/Torque capacity
02-06-2007, 05:35 PM | #1 |
Rep 342
The ZF designation for this auto is 6HP28 for a max torque of 700Nm (516 ft-lbs). Interesting tidbits about the future of auto vs DSG.
http://www.just-auto.com/article.aspx?id=90340 |
02-06-2007, 05:50 PM | #2 |
Rep 1,084
The Xede/PROcede/Prana? is already making 405 ft/lb @ the wheels with exhaust and 93 octane, you're looking at around 460-480 at the crank already so guys with 6AT's need to be aware that they are approaching this limit....
02-06-2007, 07:22 PM | #3 |
Falling in Love with German Boost
22
Rep 298
Drives: 335i, E350, Accord EX, GSXR750
Garage List 2007 BMW E92 335i [0.00]
2007 Mercedes E350 [0.00] 1994 Honda Accord E ... [3.60] 2006 Suzuki GSX-R 750 [0.00] |
There was discussion about drivetrain losses and that it's more a fixed value rather than a percentage when power has been increased. Assuming this, it's more likely around 445lb-ft. Since the car is probably underrated and actually has about 320 to 325lb-ft instead of the advertised 300, that would be loss of roughly 40lb-ft (my car put down 282lb-ft before the Xede, 358lb-ft after Xede). But it is amazing how fast the limit is approaching!
02-06-2007, 10:37 PM | #4 |
Rep 455
Im sure the trannys can take some abuse...BMW is known to have solid tranny's
There are plenty of people making over 600whp with stock e36 M3 transmitions over on bimmerforums If anything,the tranny is not the problem,its breaking other things with the added power,like rear ends,diff bolts,shock mounts,drive shafts ect. |
02-07-2007, 05:00 AM | #6 |
Rep 5,501
2007 E92 Montego Blue 335i
02-07-2007, 07:59 AM | #7 | |
Rep 5
That makes sense...(pause)...NOT!
E92 WOT
02-07-2007, 10:12 AM | #8 |
Rep 125
The other thing to consider is that they are using the same tranny for the diesels. They are already pushing high torque, so the tranny are able to take it.
11 E70 x35D
07 E92 335i* 05 E83 X3 3.0* 02 E39 540i* * Retired/Sold |
02-07-2007, 11:26 AM | #9 | |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
just my 2c, shiv |
02-07-2007, 11:30 AM | #10 |
Rep 56
What exhaust were you running here?
Silver 335 Red Leather/MT/PP/SP/CW/NAV/CA HAS ARRIVED!!!
1997 Black 4Runner Tan Cloth interior SOLD 2001 Blue BMW 528i Tan Leather interior 2/12" Alpine Type Rs subs SOLD |
02-07-2007, 11:33 AM | #11 |
1748
Rep 17,960
Drives: A Lot
02-07-2007, 11:49 AM | #12 | |
1748
Rep 17,960
Drives: A Lot
The only real problem with dragstrip style acceleration results is that revs are always above 5000rpm which means at no time are you taking advantage of the 100+ extra lbft of torque between 2500rpm and 4000rpm-- the range in which you drive in 95% of the time! cheers, shiv |
02-07-2007, 12:50 PM | #13 |
Rep 342
Shiv, I have a question,
For those who have an auto tranny, can you comment in your professional opinion about whether this tranny can take an additional 60-75 lb-ft of torque. I know you may have a bias since you are selling this, but for the past several months I have been watching your posts and am impressed with you professionalism and knowledge. We know about the "pay to play" rules of tuning but do you think this particular tranny is at its limits in terms of torque handling ability stock? Thanks in advance. |
02-07-2007, 01:03 PM | #14 |
Rep 173
What is interesting about the OP's linked article is that it does not link a specific transmission model to a specific BMW model. There is another thread in the general e90 section where the OP claims ZF tech support have responded to him directly and claimed that the e92 335i uses the HP21 tranny.
I don't have a dog in this fight since I am allergic to autos but it would be nice to know for sure. Shawn Self appointed N54 is not based on M54 police Phoenix |
02-07-2007, 01:08 PM | #15 |
Rep 173
This article seems to confirm 6HP28 is in the 335i's
http://www.zf-mediacenter.de/sea_vie...ts=&ft=&lang=e |
02-07-2007, 01:39 PM | #16 | |
Rep 148
6HP19TU for 335i = 6HP21 according to ZF = 450 Nm 6HP26TU for 330d = 6HP28 according to ZF = 700 Nm
2007 335I, " Gray", Black Leather, Step, Comfort, ZCW, ZPP, ED - Oct 5, Dropoff Oct 9, redelivery Nov 15.
02-07-2007, 02:06 PM | #17 | |
Rep 225
A PROcede modified car will eat those automatics transmissions if that is the case... Is there a code on the trans that someone can check? (I have a manual...) |
02-07-2007, 02:29 PM | #18 | |
Rep 148
Hard to check the tranny, you have to remove part of the belly pan.
02-07-2007, 02:47 PM | #19 | |
Rep 225
ZF rates the 6HP19 at 400nm (295 ft-lbs) and the 6HP21 at 450nm (332 ft-lbs) (1nm = 0.7375 ft-lbs). I doubt that ZF designed enough strength into the transmission to handle ~550nm (405 ft-lbs) from a PROcede equipped car. If BMW had installed the 6HP28, there is room to spare but probably not with the 6HP21 or the 6HP19. A 25% increase in torque over the designed numbers is huge. We will probably start hearing about failures of the automatic transmissions in PROcede equipped cars. That much torque over designed specs could cause all sorts of trouble. I suppose that only time will tell. I am glad that I have a manual! I just have to worry about eating clutches |
02-07-2007, 02:59 PM | #20 | |
Rep 148
Note that it says 6HP19 TU ( i.e updated in BMW talk) , which is the 6HP21 in ZF talk. As you said the rating is 450Nm and according to the sheet the engine rating is 400Nm. So BMW gives it a 12.5 % margin.
02-07-2007, 11:08 PM | #22 |
Rep 148
Should be ok with that, it is the ZF type G, the same one used in the M5.
