04-23-2024, 04:44 PM | #1 |
Rep 1,254
AC evaporator failure?
5k miles on my MY2023 car, last week noticed the car was blowing only cool air on the passenger and rear vents. The driver side vents blew coldish air on max AC. Dropped off the car yesterday and they said they don't know the cause but think it's the AC evaporator which sits inside the dash. Seems like a pretty invasive repair. I don't think I've seen anyone else with this issue?
04-24-2024, 07:53 AM | #2 |
Rep 6,840
That's pretty random, and an unlikely failure. I can't really tell from your post what your symptoms are. When you say cool air on the passenger and rear vents, is that full COLD air like the AC is working properly? Are you getting full cold air ANYWHERE? If so, that would mean your evaporator is working properly. And I would suspect the blending doors in the AC system to be at fault, not the evaporator. If you're not getting ANY cold air at all, then I would suspect the actual cooling system (evap, condensor or compressor) at fault. And honestly, the evap would be the last thing I would suspect since it's new and it's something that really only fails from rust. Unless it's just defective.
2011ninja3420.00 |
04-24-2024, 10:37 AM | #3 | |
Rep 1,254
A quick search on this symptom shows it shows up quite a bit on G30 cars, but not so much on the G20s. https://g30.bimmerpost.com/forums/sh....php?t=2042300 The possible evap issue is from the dealers mouth, which they have done a single day of testing with the car. I really_really hope it is not the evaporator as I saw what it. takes to get that replaced (everything from seats forward) |
04-24-2024, 10:49 AM | #4 |
Rep 5,451
Drives: 2022 Aventurin/SS G82 xDrive
It sucks, but failures happen. Nothing you can do but let them warranty it.
04-24-2024, 10:56 AM | #5 | |
Rep 6,840
2. Honestly, I wouldn't lose a minute of sleep having the dash pulled apart like that. It'll go back together fine. Take lots of pics of the interior before you bring it in so you make sure there are no scratches that show up afterwards, otherwise...you're good. |
04-30-2024, 06:56 PM | #7 | |
Rep 283
Drives: 23 M3Cx
It came in from the factory with no refrigerant, then they determined an AC line was leaking, now a year later i'm getting the Evaporator replaced. I was told it is a big job as well, not super thrilled but what can you do.
2023 M3 Competition xDrive, Alpine White with Full Fjord Blue/Black interior
2022 Acura TLX Type S, Tiger Eye Pearl with Orchid White interior (traded in) 2019 Subaru WRX STi, Ice Silver (traded in) 2017 Ford Focus ST, Oxford White (traded in) |
04-30-2024, 07:21 PM | #8 | |
Rep 1,254
Krisp97302.50 |
04-30-2024, 09:03 PM | #9 | |
Rep 283
Drives: 23 M3Cx
The evaporator is supposed to arrive soon but it's a big job getting access to it under the dash.
05-01-2024, 08:13 AM | #12 |
Rep 283
Drives: 23 M3Cx
That is crazy. How wasn’t that covered? I’ve never had an issue getting my issues approved in the 8 visits I’ve had for warranty issues
05-01-2024, 08:25 AM | #13 |
driver
820
Rep 781
My car was modded to much according to them, although none of the mods had anything to do with the AC system.
Tried a few dealers around me and none happen to be aftermarket mod friendly. Was for the better anyway. I didn’t like the idea that a new tech would probably for the first time in his career rip up my dashboard out and not forget a few nuts and bolts at the end. Funny thing, I did this twice. The first time I took my evaporator to a radiator repair shop to have it repaired and that worked for about a month lol. Next time I just bought the entire AC evaporator and blower assembly from eBay and it’s been going strong ever since. These do have a known weakness, same evaporators are used on a few different bmw models and I believe on the x3 they do have a service bulletin out for it. Here is where the leak was and my initial fix which didn’t work. The evaporator pipes are very flimsy and to me it looks like a very poor design |
Krisp97302.50 |
05-01-2024, 09:49 AM | #15 | |
Rep 283
Drives: 23 M3Cx
05-01-2024, 09:59 AM | #16 | |
Rep 1,064
05-01-2024, 09:59 AM | #17 | |
driver
820
Rep 781
Krisp97302.50 |
05-01-2024, 11:41 AM | #18 |
Rep 283
Drives: 23 M3Cx
Far past that point, outside of the 1 year criteria and didnt expect to continue having issues. I have considered ordering a 2025 at times but prices have continued rising along with rates vs. when I bought mine.
2011ninja3420.00 |
05-01-2024, 11:43 AM | #19 |
Rep 283
Drives: 23 M3Cx
Yes it does. They claimed to have seen dye leaking in those areas when they did previous repairs so that is why they amended those parts. Now somehow two days in to diagnosing this time, BMW instructed them to replace the evaporator which it now seems is a weak point. But like other things, BMWNA doesnt want to jump straight to that first.
coldsteelrain820.00 |
05-05-2024, 11:01 AM | #20 |
Rep 283
Drives: 23 M3Cx
Happy to report I have it back and have ice cold air.
'Cane8732.50 coldsteelrain820.00 |
05-07-2024, 12:39 PM | #22 |
Rep 283
Drives: 23 M3Cx
That is absolutely ridiculous. Its like they don't try to figure out what is causing these issues and revise the design. Hearing things like this make me reconsider keeping the car long term.
