03-08-2024, 12:28 PM | #1 |
Rep 91
Drives: 2020 X5; 2016 M235i Conv. 6MT
Heat loss at low battery level
Hi all, I just did my first long road-trip in my i4. While it went ok, I noticed something a bit alarming. As I got down around 20-25% battery, the climate control started to only blow cool air, even when I turned up the temperature. Is that something I should have expected? Is it a result of the battery preconditioning for the fast charger? Or is it potentially a coolant issue?
(Sidenote: I had the coolant changeover valve issue, but have already received a new valve.) |
03-08-2024, 07:27 PM | #2 |
Rep 438
I posted an answer in the other forums. For my car, I can get heat down to 10% soc (probably lower but never have I gone lower so I don't know). Also the mode the car was in also affects this, Eco Pro vs Comfort/Sports. Other wise, there have been multiple people who had the coolant valve changed, have the heater fail shortly afterwards so if it continues, I would take it back to the dealer.
RichardInCA2535.00 |
