01-31-2024, 02:49 AM | #1 |
Rep 31
calling all dif swappers...
I'm considering swapping my dif (06 n52 3.0 manual) to something with a higher final drive for a little more neck breaking action, and so that I can spend more in gas. I believe I have the 3.46, and im thinking I want to go up to 3.91 (those can be sourced from the e46's right?). So I would like to know:
what ratio did u swap to? where did u source your dif from? is the difference actually noticeable? will I still lose races? thanks. |
01-31-2024, 05:41 AM | #2 |
10980
Rep 4,912
Which car do you exactly have? the n52 in 3.0i trim or the n52 in 3.0si trim?
The (manual) n52 in 3.0i has a 3.38 final drive and the (manual) n52 in 3.0si has a 3.23 final drive according to the spare parts catalog. So I think there's no possibility you have 3.46 3.91 is afaik a ratio used in the e36, not the e46. Are you gonna do the swap yourself? What kind of races are you loosing at the moment?
01-31-2024, 11:51 AM | #3 |
Rep 565
There’s a thread think buried now with this: https://web.archive.org/web/20200729...calculator.htm
solo the lad7.50 |
01-31-2024, 01:30 PM | #4 |
10980
Rep 4,912
Yes, X3 diffs might be a drop in replacement. e8x 1 series not.
The x3 was fitted with a 3.91 ratio That said, you can only use the 3.91 from the manual 2.5i and 3.0in52. the automatics 3.91 have a 168 diff, not 188 according to the parts catalog. Those differences are not in that specsheet but is crucial for fitment.
solo the lad7.50 |
01-31-2024, 01:41 PM | #5 | |
Rep 31
01-31-2024, 01:42 PM | #6 | |
Rep 565
GuidoK10979.50 |
01-31-2024, 01:51 PM | #7 | |
Rep 31
01-31-2024, 01:54 PM | #8 | |
Rep 565
I swapped to a lsd from diffsonline to a 4.10 and 1st if you blink you’re already in 2nd. There’s times it’s beneficial times it’s not. One track by me has a long straight I can utilize 4th, another track I was at for the first time last year the longest straight I barely kissed 4th so it made more sense to back off than up shift and down shift as soon as you were to upshift. It all depends what you’re wanting to obtain from changing your final drive gear. I also added an ess vt1 when doing my diff so there’s very madness to the meaning. Last edited by Piper1; 01-31-2024 at 02:21 PM.. |
01-31-2024, 02:33 PM | #9 | |
10980
Rep 4,912
I drive with the stock 3.07 and 1st gear is completely useless. If any I'd like a longer 1st gear, 2nd gear is fine and 3-4-5 could be more close ratio for spirited driving, and I'd like 6 to be much longer, as a cruise gear on the highway. Too bad it's virtually impossible to change the gearbox ratio's without breaking the bank.
01-31-2024, 02:38 PM | #10 |
10980
Rep 4,912
That greatly depends on what exact diff you're choosing.
01-31-2024, 03:38 PM | #11 |
Rep 199
Drives: BMW Z4C 3.0si 3 pedal
07 3.0 si manual, Switched to a 3.73 , 5 disc clutch type diff. Car is still drivable at hwy speeds , very reactive to acceleration at speed.
five, 104mm diameter friction discs ( type 188K discs are normally only 90mm) , for longevity , as a result of less load per square mm over time - maintained static , set to 35% ( 110Nm) as your baseline for best case inside wheel spin control, without generating any oversteer - asymmetrical dynamic locking (throttle controlled) favoring accel ( from 35% up to 100% , if called upon), over decel ( limited to 60% max) to avoid rear wheel lockup during hard decel Custom diff by Jim Blanton at Performance Gearing, great guy and very knowledgeable on on how to set up diffs, great warranty and best prices for complete drop in diffs. |
01-31-2024, 09:44 PM | #12 |
Rep 199
Use this gear ratio calculator to figure out your max speeds for each gear using whichever final ratio you choose. Make sure to use either the correct Manual or automatic gearing ratios. And change the tire size to match yours.
E86Z4 3.0si / M Coupe Manual I: 4.35 II: 2.50 III: 1.66 IV: 1.23 V: 1.00 VI: 0.85 Reverse: 3.93 Final Drive: 3.46:1 Redline: si 7,000 / M 8000 E86Z4 3.0si / 3.0i Coupe Auto I: 4.17 II: 2.34 III: 1.52 IV: 1.14 V: 0.87 VI: 0.69VII: -Reverse: 3.40 Final Drive: 3.64:1 / 3.73:1 Redline: 7,000 https://web.archive.org/web/20200729...calculator.htm Last edited by cbpip; 01-31-2024 at 09:56 PM.. |
01-31-2024, 11:58 PM | #13 |
Rep 12,569
On my old 3.0si manual I swapped in a 3.73 from a Z4 auto and it was the best balance for street and track. It was still driveable on street while giving me the much needed torque coming out of low speed turns (i.e. hairpins) on track. Best part was it was quite cheap as I didn’t need to rebuild anything; it was direct swap.
02-01-2024, 09:10 AM | #14 |
Rep 199
3.73 from an Z4 auto would have been an open diff not an LSD.
02-01-2024, 11:03 AM | #15 | |
Rep 565
02-01-2024, 05:56 PM | #16 |
Rep 12,569
Yea no kidding. OP didn’t ask about limited slip.
solo the lad7.50 |
02-01-2024, 11:29 PM | #17 | |
Rep 31
02-02-2024, 06:02 AM | #18 |
Rep 12,569
Correct
