Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Weird Noise - clip need some help
Reply
      01-15-2024, 09:04 AM   #1
kiquos
kiquos's Avatar
Drives: 2011 E92 M3
2011 BMW M3  [0.00]
Hello Fellas, so I get this noise ONLY when I break at low speed. The wife calls it the Cat!
2011 BMW 328i 88k miles, just bought it.
I've bleed the brakes twice and twice I've ran the Bleed program for the ABS.
The noise does NOT happen when I break and the engine if OFF. (how you ask, I drive, go on Neutral and turn the engine off at speed and I break). Done this several times, repeatable. This leads me to believe that its not the breaks (Unless their vacuum needed from engine?).
It sounds like a belt, but the belt is New and both tensioner and idler pulleys are new.
Maintenance done (oil, filter, flush brake fluid, and power steering fluid, radiator flush.
Anyone else get this cat??
https://youtube.com/shorts/eOct2qMrjiw?feature=share
Reply
