11-05-2023, 03:13 PM | #1 |
Rep 121
App and charging
I keep setting my app to charge the car at 23:30 each night but it seems to ignore it and charges immediately. It used to work ok. Anyone else with the same issue?
11-06-2023, 06:49 AM | #3 |
Rep 121
Does it stop after a couple of minutes? It is normal for it to charge when first connected so it can calculate the charge finish time based on the power provided… it will consume approx .25KW whilst it does this.
11-07-2023, 09:17 AM | #4 | |
Rep 121
WHen i toggle in the app between charge immediatley and charge in time period the "update in bmw" doesnt activate. |
11-16-2023, 09:39 AM | #5 |
Rep 21
Charging iX3 via Octopus Go tariff
I have struggled for days trying to create a simple charging regime.
My desired scenario: 1. Plug in charging cable connected to Easee 32A 7.5 kWh wall charger on arriving home 2. Get confirmation via My BMW app that charging commenced then was stopped by the Octopus Go managed charging app to await low tariff time 3. Charge between 11:30 and 05:30 at low tariff 4. Enjoy next journey knowing any battery charge was achieved at low tariff. Instead I keep finding the car second guessing when I want to depart and Easee app wanting to charge during high tariff period. I’ve tried disabling departure times, charge immediately, charge during 11:30 to 05:30 time slot and Bump charging via the Octopus app. Is life really this difficult? Any suggestions on optimum settings between car/charger/Octopus app? Thanks in anticipation that somebody understands the required settings. |
11-17-2023, 07:41 AM | #6 |
Rep 57
I have a wallbox charger.
My car settings are set to charge immediately. I have a scheduled charge time set in the wallbox app. I plug in the car, unlock the charger and it just sits and waits for the scheduled time on the wallbox app. Very simple, no issues. Doesnt try to do a charge when I plug in initially as the wallbox is not supplying power. |
