BMW 3-Series (E90 E92) Forum
MILVS are back
09-11-2023, 02:05 PM | #1 |
Rep 4,195
MILVS are back
I spoke to Marty a few days ago and he made me aware that he has MILVs back in stock.
Just passing the news along for anyone who needs/wants them.
Mods: Yes.
09-14-2023, 12:34 AM | #2 |
Rep 154
Anyone seen this? BDS testing does not show a benefit. I have MILVs but never did a before or after dyno. Not sure if anyone has done their own bench testing?
https://www.facebook.com/bdsmotorsportuk |
The Nightman1091.50 |
09-14-2023, 09:57 AM | #3 | |
Rep 4,195
I had them on my N52 and now on my N55.
Mods: Yes.
PhaceN52174.50 |
09-14-2023, 01:46 PM | #4 |
Rep 154
He does have a very good reputation in the UK Motorsports world and the findings are from bench testing. If I am honest I can not see how MILVs don't improve valve lift and duration as you are dropping the lever closer to the valve. But the Valvetronic is a complicated design so hard to say for certain. I never got my N52 dyno'd before and after my MILVs installation so can't confirm or deny what he is saying.
09-14-2023, 02:15 PM | #5 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Cool, didn't realize Bruno started playing with N52s. He seems to know his stuff, at least based on his appearances on Car Throttle... His posts about the N52 are interesting, and he posts dyno graphs for most updates:
Jul 13: V1 tune for N52B30: 251 to 264bhp and 233 to 245tq https://www.facebook.com/bdsmotorspo...wvabYpnjmQmkJl Jul 14: N54 intake manifold on N52 - "torque curve is worse everywhere only really improoves on the last 500rpm, this means avg power would actually be worse" https://www.facebook.com/bdsmotorspo...1dzARpK3RMvNrl Aug 19: testing their own intake, no gains over stock eurobox https://www.facebook.com/bdsmotorspo...C88xyKGZRcdyUl Sep 1: 280bhp (238whp) with their valvetronic arms (?), intake elbow and tune https://www.facebook.com/bdsmotorspo...NR9KBhfh95Xnkl Sep 13: finished their own intake (with ITG), 6% more air flow than stock eurobox with stock filter claimed. No dyno (yet?) https://www.facebook.com/bdsmotorspo...9VwjTVkWUJbvUl Sep 14: MILVs - "doesn't align with our vision for our tunes" https://www.facebook.com/bdsmotorspo...gwTZ19HMpCWNbl A little more information in the comments, but Bruno doesn't really offer any details to support his position ie "trust me bro" "Jon Williams: There's been lots of chat behind the scenes on MILVs since you started testing and found the 'fake' MILVs added no lift. I know you have recently tested some of Marty's MILVs from BimmerMILVs. The principle of the MILVs makes sense, drop the intermediate support and you effectively push the intermediate lever lower pushing the valve down more. The complication is all parts are floating between cam and eccentric shaft and HVA/valve support and any change could change the geometry of how they all interact. I believe you found that Martys MILVs do push the intermediate lever down but their movement pushes the HVA down not the valve and hence valve lift is basically the same between OEM and modified part. I guess my question is, that proves the theory that pushing the support down, pushes the intermediate lever down, could it be that with the HVA pressurised in a non static bench test the Marty MILVs would actually cause the valve to open further rather than push the HVA down? I guess it would depend on what force the oil pressure exerts on the HVA, mechanical advantage of the lever and the spring rate of the intake valve." "BDS Motorsport: look at it better and it doesn’t make sense as what opens the valve on these is not a motion downwards…" "Jon Williams: I don't follow? To open the valve it must move down against the valve spring. To move the valve down a downwards force has to be applied, that's Newtons Laws. The downward force is from the intermediate lever which is acted upon by the cam?" No further discussion... Last edited by The Nightman; 09-14-2023 at 02:23 PM.. |
PhaceN52174.50 |
09-14-2023, 06:45 PM | #6 | |
Rep 4,195
09-15-2023, 12:54 AM | #7 |
Rep 154
Yes that was me who posted the question to BDS and I have had a private message from Bruno back, not a reply on the public thread. If I am honest the message did not fully explain why HVA pressure would not impact the valve lift, however, it looks like Marty might be testing the MILVs with the same parameters as BDS to either prove or disprove the testing.
To be open and honest I have MILVs fitted but never tested before and after. I thought they improved mid range torque from my butt dyno but the changes with NA mods are generally so small that is not an accurate measure! I would argue some of the increases are even hard to prove with dyno runs, is a 5hp increase dyno tolerance or real gains/losses. Anyhow the principle of MILVs makes complete sense to me as an engineer. However, I do concede that the Valvetronic is a moving feast, geometry never stays constant so hard to be certain without bench testing. Marty did this and is a great guy who would not maliciously mislead anyone. Flip side BDS have a great reputation from what I can tell, Bruno is a friendly guy who I think genuinely wants to get as much power out of the N52 as possible. As you say he comes across well in the YT videos he has been on in the last couple of years. I will wait and see how this all unravels. |
The Nightman1091.50 ornicar136.00 |
09-15-2023, 07:39 AM | #8 | |
Rep 364
Drives: 2007 BMW 328xi E92 6mt swap
09-15-2023, 02:22 PM | #9 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Do you have any information about their "valvetronic arms" mentioned in a couple posts? I'm also curious about the "fake" MILVs being sold by someone out of London, which apparently don't work? |
09-16-2023, 12:50 AM | #10 |
Rep 154
I think the fake MILVs were being sold by a guy through Facebook and maybe Instagram, I forget his username. He claims he 3D scanned the BimmerMILVs and got them machined the same. I think BDS testing found the quality and finish of the BimmerMILVs superior to the fakes but ultimately their testing concluded on a UK spec 130i engine they did not add lift. There is a theory that the US engine maps come with less Valvetronic lift as standard based on the roller marks on used supports. I guess to confirm that a tuner would need to look at a UK 130i tune and a US 328i tune
ornicar136.00 |
09-16-2023, 07:36 AM | #11 | |
Rep 4,195
If I had to guess, those should be the fakes. |
dindf0.00 |
09-16-2023, 07:15 PM | #12 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
"bimmermilvs 2w @saadahmed95 You admitted you outright copied my parts. I have your email where you admit it. And they are not 100% identical. Your counterfeit parts are just that and they don’t work." |
09-16-2023, 07:30 PM | #13 | |
Rep 4,195
Sad that those guys got suckered into buying fakes - but why would you even chance it? Marty’s has been proven to work, and I don’t know who this guy is - but it seems scummy to even copy someone work to sell them for ‘cheaper?’ - it’s only $300usd for used ones - plus $40 back. It’s an absolute deal. As for this tuner - UK/EU tuners have always and will always be inferior to US based tuners. Evolve, despite being located in the EU - was trash at tuning the N52, even though they got the 265hp 130i variants, and every other tuner I’ve seen is just average at best. They all sell the same canned tune variant anyhow. Marty actually remapped the entire valvetronic table so it can be used with the MILVS. Just putting Max lift at 11mm likely won’t work which is why these guys are speaking nonsese. For what it’s worth, Hassmachine mapped all the standard times - he has MILVS and hey work for him (he custom tuned it himself) Bob from STAGEFP also tested them on a 330i - again? Gains were shown. Being a bad tuner and using trash parts doesn’t mean the real thing doesn’t work Last edited by AmuroRay; 09-16-2023 at 07:41 PM.. |
PhaceN52174.50 |
09-17-2023, 12:53 AM | #14 | |
Rep 154
09-17-2023, 10:17 AM | #15 |
Rep 288
Drives: 2009 328i
I couldn't imagine wanting to go through the process of uninstalling some ineffective copies and then doing the job AGAIN on the good ones. All I know is that the legit MartyMILVS in my 328 were quite an improvement when tuned properly.
09-18-2023, 05:47 AM | #16 |
Parts Pro
65
Rep 134
Drives: 2007 BMW 328xi 6MT
Support the Cobra and buy Marty’s BimmerMILVS. He’s the one who did all the research and hard work. I got mine on the way happy to see them come back in stock recently
E90 328xi 6MT | Intake Scoops | K&N + Charcoal Filter Delete | DIY Dinan 3in | 3.25in + 3.5in piping | N54 Manifold | Ceramic Coated Headers | Secondary Cat Delete | Xdelete | 3.91 Diffs | 22RPD Tune
The Nightman1091.50 PhaceN52174.50 |
09-24-2023, 03:59 PM | #17 | |
[Oo=||=oO]
1105
Rep 2,470
Regarding rest of the thread. WTF.... I come back to these forms after serious hibernation and find shitposting about how MILVS don't work. LOL! They do not work without proper tune. Difference between modified and not modified supports is so slight that it is almost impossible to notice it as I think the difference is few mm of not less. There will be absolutely no difference when running MILVS on stock tune or any other tune that is not accounting for it. Once you get a proper tune, you will definitely feel the difference. I've had MILVS on my car almost since they came out (sometime in 2018) and never looked back. |
09-24-2023, 07:30 PM | #18 | |
Rep 4,195
09-26-2023, 12:57 PM | #19 | ||
Rep 4,195
Read through again, it looks like they are claiming they have their own solution which is a replacement of the "valvetronic arm" or maybe the eccentric cam itself. Claimed 20whp with the tune. Hmm...It should be said their tune was the same end result BPC/Stage FP got on the MILVs with a tune - 238WHP? https://www.e90post.com/forums/showt...4#post21645184 Quote:
Mods: Yes.
ornicar136.00 |
