08-10-2023, 02:29 PM | #1 |
BimmerPost Supporting Vendor
24378
Rep 191,194
Dorch S58 Flex Fuel ECA Kit **NEW PRODUCT**
Now that S58 tuning software supports true CAN-based Flex Fuel tuning, we are offering our own plug and play ECA solution! With CAN, there is no longer much of a need for Bluetooth ethanol sensors. A CAN-based ethanol sensor, can not only monitor ethanol content, but it will also directly communicate with the DME for full Flex Fuel operation. With a Flex Fuel tune, the DME will automatically adjust the tune from a high-powered E85 map, all the way to a pump gas map, and everything in between. This all happens on the fly, based on the live CAN-communication with our ethanol sensor. Gone are the days of doing math at the gas pump only to decide which map to flash and how many gallons of ethanol to mix! ZERO cutting and ZERO wire-taps! This kit is fully reversible and truly plug and play. The wiring integrates into the OEM harness and hoses and sensor tuck seamlessly to allow for reinstallation of all OEM sound insulation foam and engine covers. With the ethanol sensor mounting location as close to the injectors as possible, there is virtually zero lag time on the exact ethanol mixture truly entering the combustion chamber. Don’t be fooled by our extensive and overly detailed, DIY-friendly instruction manual! You can expect this kit to take about 1 hour to install (depending on skill-level). Kit Contents: Zeitronix ECA-CAN Module Custom PTFE Hose Set Dorch Plug-n-Play ECA Harness Genuine Continental Ethanol Sensor Pre-cut Firewall Grommet Mounting Accessories Kit Fitment: G80 – M3 G82 – M4
Check out our current sale by clicking on this link!
https://x-ph.com/sale/ Phone number 702-494-9435 |
08-19-2023, 10:26 AM | #3 | |
24378
Rep 191,194
08-20-2023, 02:12 PM | #5 |
24378
Rep 191,194
01-11-2024, 11:28 AM | #6 |
Rep 468
Sorry if I missed this. Which tuning platforms is the DME/CAN flex integration compatible with?
All of these? MHD+ (when it’s released) BM3 Ecutek Trying to find a pnp flex fuel kit for my F97 that will work with multiple tuning platforms. |
Vectors2final1452.50 |
04-08-2024, 09:59 AM | #8 |
24378
Rep 191,194
Im not familiar with MHD, I recommend you check with them directly
LuiG0.00 |
