Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 compression numbers: Help me decipher
Reply
      05-21-2023, 06:02 PM   #1
r3vmatch
Drives: 3.0si Roadster
All,
I'm trying to troubleshoot a rough idle(+/- 10 RPM) low RPM performance loss on an N52/2006/70K miles. Symptoms include soot on tail pipe, so I thought replace DISAs, CCV and breather hoses (all look to be 2006 original). Decided to compression test before throwing a bunch of $$ at the car.
Are these numbers worrying? Specifically that the hot / cold PSI are close to each other? Edit: Re-ran on #5 & 6 cold and all the cold numbers are in line with each other.
Numbers hot[PSI]: 218.0, 221.0, 218.0, 219.5, 224.0, 218.5
Numbers cold[PSI]: 219.5, 225.5, 221.0, 223.0, 215.0, 211.5
Notes:
  • Idled car up for 15 mins, temp gauge in middle to do "warm" test. Steam came out of tail pipe even after 15 mins but NOT white smoke, no sweet smell. Car has not been driven very much in the past year. Car had electronic water pump+thermostat replaced by previous owner when they failed, not sure to be worried about warped head gasket or not
  • Cold test done with car sitting for 24-hours
  • All EFI fueses pulled and all spark plugs pulled (per other forum postings on how to compression test)
  • Using a brand new Mittyvac digital compression tester which automatically measures peak values
  • Throttle body completely removed for both tests
      05-21-2023, 06:13 PM   #2
r3vmatch
Replying to my own thread:
Re-tested #5 & #6 cold and got 220.5 & 224.0 PSI . So all the cold numbers in theory agree with each other.
      05-22-2023, 03:56 AM   #3
Saico
Drives: 330xi
220 psi = ~15 bar. For my taste that's very high.
      05-22-2023, 07:10 AM   #4
Tambohamilton
Drives: E91 330d
Have you checked for fault codes using INPA/ISTA? Have you checked smooth running test?
      05-22-2023, 06:50 PM   #5
r3vmatch
Hi, thanks for the replies.
A) If 220 PSI is too high, what is that an indication of? Excessive carbon build up?
B) No codes in INPA or Rheingold. I did check the smoothess values but I didn't take a screen shot . I started on pulling the intake + CCV so it'll be a few days before I can report back. I did find some oil on the 'inner' DISA connector (haven't gotten intake off yet) so I know this has to be dealt with anyway.
The tail pipe is sooty and when I pulled the large DISA I found several tablespoons of oil, so perhaps a failing CCV has been allowing too much oil into the pistons.
I did take pictures of the sparkplugs, I can post that.
Reply
