TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Random no start issue on 2006 BMW 330
Reply
      03-09-2023, 11:05 PM   #1
bootsncats24
Drives: 2006 BMW 330i
Recently purchase a 2006 BMW 330i that has a random no start issue. First start of the day always starts up with no issues. After being driven it will randomly not start. No crank nothing. Let the car sit and it will start back up. Sometimes it will start up 30 min later sometimes it takes a couple hours. I've tried jumping the car and it wont start. I've tried connecting a jumper cable from the jump start ground in the engine bay to the bolt on the oil filter housing doesnt make a difference. I do not have any check engine codes. I'm hoping its not the starter but I don't know what else it could be. I'm about to take to the dealership since it does need two recalls done for it. One for the HVAC and for the PVC Valve heater.
Anyone have any ideas?
      03-09-2023, 11:35 PM   #2
whyzee125
Drives: Dinan stage 2 335i
Could be the starter or could be a grounding issue. It could be many thing really but those two are most likely.
      03-10-2023, 09:29 AM   #3
bootsncats24
thanks that helps alot. I wasn't sure if it could still be the ground strap if the car wouldn't start when I tried using jumper cables to ground it.
      03-10-2023, 11:09 AM   #4
Pittz1
2018 M3 ZCP / 06 330xi
211
Drives: 330xi 2006 / 18 M3 ZCP
Starter. 100% people do not want it to be because the labor that is involved, but someone that has an 06 and has gone through this, change it.
      03-10-2023, 11:46 AM   #5
bootsncats24
Thanks. I checked ground strap for the starter this morning. Its green going to change that first. If it is the starter its going to an indie.
      03-10-2023, 12:49 PM   #6
chilledn52
Parts Pro
chilledn52's Avatar
65
Drives: 2007 BMW 328xi 6MT
2007 BMW 328xi  [10.00]
Sounds like a worn bushing within the starter, landing on a dead spot. Recommend replacing starter
E90 328xi 6MT | Intake Scoops | K&N + Charcoal Filter Delete | DIY Dinan 3in | 3.25in + 3.5in piping | N54 Manifold | Ceramic Coated Headers | Secondary Cat Delete | Xdelete | 3.91 Diffs | 22RPD Tune
Reply
