03-21-2022, 04:13 PM | #1 |
Rep 1,203
Drives: 2023 BMW i4 M50
BMW wall mount for Flexible Fast Charger
Now I know I might be getting ahead of myself on this one since most if not all of us are still waiting for our deliveries, but since in the US at least, the i4 comes with the flexible fast charger I do not see the reason to buy another charger, initially at least.
I've seen the following part at the BMW dealers in Europe. "61 90 5 A13 A62" This is a very elegant wall mount option for the flexible fast charger. I'd like to get my garage prepped for this so I don't have cables laying around. Does anyone know the equivalent part in the US? Or something similar? Last edited by cruzer666; 03-21-2022 at 04:20 PM.. |
03-21-2022, 05:10 PM | #2 |
Rep 399
Drives: 2023 BMW i4 eDrive40
Part number is the same
I believe that the part number "61 90 5 A13 A62" is the same in the USA. The only place that I found it available is ECS Tuning.
https://www.ecstuning.com/Search/Sit..._90_5_A13_A62/ wally |
cruzer6661237.00 deutsch1003945.00 |
03-21-2022, 09:43 PM | #3 | ||
Rep 1,203
https://www.getbmwparts.com/oem-part...80-61905a13a62 It was $59 shipped from Germany. It will take a month or two to get; good thing I'm in no rush 🙂 |
03-23-2022, 03:50 PM | #4 |
Rep 1,203
I got an email saying the part is blocked in the states and my order was cancelled. This is new!
03-23-2022, 04:45 PM | #5 |
Rep 399
Blocked?
What does “blocked” mean.
Surely US Customs is not preventing these parts from coming into the USA. Wallyf |
03-23-2022, 04:47 PM | #6 |
Rep 1,203
03-23-2022, 05:54 PM | #7 |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
What site did you order it from?
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
03-25-2022, 08:57 AM | #10 | |
3101
Rep 3,470
Also, did you trying calling ECS Tuning?
03-25-2022, 09:12 AM | #11 | |
Rep 1,203
Yep, it comes with the adapter for NEMA 14-50 outlet which uses a 50AMP circuit (9.6kW charging). If you got the direct wire charge point then you're getting 11kW charge rate (60AMPS) I believe. For me 50AMPS is more than sufficient, I'll still get a full charge overnight, so I couldn't justify spending the money for a separate charger. |
Haywood3100.50 |
03-28-2022, 08:22 AM | #13 |
Rep 98
As usual it depends. If your home charger is of the plug in type then you are limited to 9.6KW (240V * 40A). The 9.6KW limitation is based upon the max allowed continuous voltage for a NEMA 14-50 plug. If you want to hardwire your charger then you can go very high. I've seen chargers that will do 24KW (240V * 100A).
03-29-2022, 10:18 AM | #14 |
Rep 127
FYI - BMW NA does not allow US dealers to sell parts not specifically for models NA imports or imported to the US. It's been a problem even for classic cars, if the model was not one BMW NA officially imported. One must find a foreign source. No likely US customs knows or cares.
03-29-2022, 10:49 AM | #15 | |
Rep 8,016
03-30-2022, 05:39 PM | #16 | ||||
Rep 14
If you already have a 3 phase supply to your house, you could have elected to go for a 22 kW charger. |
04-05-2022, 05:29 PM | #17 |
Rep 1,203
I just got this delivered, ready for the mobile charger 🙂. The cable management part (on top of the picture) is metal, the charger mount is heavy duty plastic.
motzus66.50 deutsch1003945.00 |
05-07-2022, 09:04 PM | #18 |
Rep 352
other than the mount for the mobile charger, i would just buy a generic cable management system off amazon, lots of options here...
https://www.amazon.com/ev-charger-ho...charger+holder I'm trying to see if someone has 3d printed one yet so i can just get the stl file. to be honest I wouldn't splurge on the wallbox type chargers, you won't get much more out of it, and it's doubtful you are going to bring your mobile pack with you and plug in to a 110 (not even worth it). Some people with a 2nd home maybe but even then it's not much of a problem to bring with you. I found with my tesla model s i used the mobile at home on a 30amp electric dryer plug and it was good'nuff' for an overnight charge. If you are charging more than 1 vehicle then I would say do it. In our new house I was very lucky in that they put in 100amp sub panel when they did our hot tub that was right on the garage wall. I ran everything myself on a 50amp with a 14-50. Tesla recommends a GFCI breaker with is about 120 bucks unless you are directly wired into a wallbox. I think if it's off the ground in a garage you are likely okay, but the code is the code for a reason i guess.... Pretty excited for the i4, did a test drive yesterday when I finalized my other, that car is everything I hoped the tesla would be and more, way more luxurious inside, way better driving feel and like 20K less... amazing how far things have come |
05-11-2022, 07:06 AM | #19 |
Rep 352
pretty sure this will work for those of us with 3d printers... those of you who have taken delivery please confirm....
https://www.thingiverse.com/thing:4840386 |
07-20-2022, 09:16 AM | #20 |
Rep 189
07-20-2022, 10:13 AM | #21 | |
Rep 1,203
07-20-2022, 10:19 AM | #22 | |
Desert Rat 1
15
Rep 263
2011 BMW 335is - Alpine White/Black, DSG
1989 BMW 325is - Zinnoberrot/Black 2009 Audi R8 - Ice Silver/Black (gone, but not forgotten) My BMWCCA Gallery |
