Forum for the entire range of BMW electric vehicles
BMW i4 Forum - i430, i440 (G26) EV Forum BMW i4 Forum - M50, eDrive40, eDrive35 (G26) EV Forum
      01-02-2022, 09:02 AM   #1
P2
P2's Avatar
53
Drives: 2023 i4 M-Sport eDrive 40
Single Motor Traction Functionality
Does anyone understand how the single motor eDrive 40 provides traction? Is it similar to an open differential like my old 2006 325 RWD? Or is it like a limited slip or fixed differential?
I'm thinking ahead to slippery street driving in ChicagoLand. I had the 06 RWD for 11 years and learned to drive in Western NY on RWD. So, I'm no stranger to snow and open diffs. Wife is not a fan however. . Just wondering what to expect.
      01-02-2022, 10:26 AM   #2
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
The traction control is embedded in the electric motor management system, and what BMW calls "near-actuator wheel slip limitation" means that this is an open differential where the traction, front/rear torque distribution and slip are all controlled by the motor management system.
      01-02-2022, 01:34 PM   #3
P2
P2's Avatar
53
Thanks. I read up on what little I can find on this.
If I understand correctly, minus any electric assist, the low (or no) friction wheel will spin while the wheel with friction will remain stationary along with the vehicle . The i4 uses the "near-actuator wheel slip limitation" to slow the low friction wheel which they claim to be more effective than the DSC system which I would have had on my 06 325 RWD.
I see the i3 uses this system. I did search for some info on i3 in the snow and will do so some more.
      01-13-2022, 04:10 AM   #4
WallyF
WallyF's Avatar
97
Drives: 2023 BMW i4 eDrive40
I3 near actuator limited slip
P2,
Have you found out any details on the i3 near actuator limited slip? How does it work to limit the spin of the low friction (slipping) wheel?
Thanks
WallyF
      01-13-2022, 04:19 PM   #5
P2
P2's Avatar
53
Originally Posted by WallyF View Post
P2,
Thanks
WallyF
Not anything more then above.
      02-02-2022, 06:23 PM   #6
WallyF
WallyF's Avatar
97
Staggered vs Square setup for snowy roads
Which is better for driving on snow and ice covered roads using all season tires? Staggered or square setup?
Wallyf
      02-03-2022, 01:51 PM   #7
Rich9600
Rich9600's Avatar
Drives: i4 M50
Wallyf
Thinner rear tyres give more road pressure and bite in better. The logic on previous RWD BMW's was to go square for snow.
However, on driving an e40 I took a photo of the tyre options. Thinking of winters for my order.
Square 18's at H rating and Slightly Staggered 19" 'performance' winter tyres at V are both listed for the MSport e40.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31)
bmw
