12-24-2021, 03:51 PM | #1 |
Rep 1
Installed lowering springs and now struggling with bumps!
I purchased some lowering springs for my Z4 3.0i SE roadster as the stock springs were too soft for the track and the car sat a bit too high (the arch gaps were too much for a car like this). The springs are rated at 30mm, which was the only size available from 4 different manufacturers on Demon Tweeks.
The little roadster now handles a lot better and feels more responsive! However..... the front wheels are now hitting inside the arches when going over the smallest of bumps and making a lot of speed bumps unbearable. Has anybody else had this experience or have any ideas on how to simply rectify without having to change everything again? I've been considering replacing spring pads with some thicker ones. P.S. I already went through the effort and cost of replacing all the shocks last year and didn't have time to consider alternative options before the first track day booked for it, hence why I haven't done coilovers. |
12-24-2021, 04:05 PM | #4 |
Rep 685
Have you checked the control arm bushings? Sometimes that can cause it to rub on the back arches since your springs can't give as much. I blew one of my struts this year while tracking, caused my front right to hit often.
12-25-2021, 11:11 AM | #5 | |
Rep 267
Drives: 2006 Z4 M Roadster
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
12-25-2021, 11:28 AM | #6 |
Rep 145
Pick up some camber shims. Cheap and effective
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
12-28-2021, 10:54 AM | #8 |
Rep 12,565
Don’t think camber shims work on non-m.
OP - you need to tell us your wheel and tire sizes along with alignment settings. Last edited by 3002 tii; 12-28-2021 at 11:33 AM.. |
