12-20-2021, 02:59 PM | #1 |
Rep 4,210
Change for change's sake
I have a BMW 530e and the charging port is on the left front of the car. I installed a clipper creek charging unit convenient to that.
Now I am looking at the I4 on the BMW web page and lo and behold, they put the charging port on the lower right side of the car. The exact opposite. It seems to me that BMW is making too many changes for no discernable reason except a desire to change. Buttons and switches work well, so BMW has been moving to touch screens instead (to be fair, so are most of its competitors); Several times it has changed the way the turn signal works; the reverse tach (allegedly to give room for the display in the center but that makes no sense as a tach moving in the opposite direction would leave the same amount of room; etc. etc. I am not even mentioning the snout. |
12-20-2021, 03:26 PM | #2 |
Rep 136
Drives: X5 45e M Sport
The charging port replaces what would be the fuel intake on the ICE 4 series.
Just reverse the car in and you'll be fine! |
12-20-2021, 03:29 PM | #3 |
Rainbow Racer
1008
Rep 2,539
I concur, I think the metal stamping of that body panel is already molded from the ICE. Replacing a bolt-on front fender is easier to accomplish vs having a seperate stamp for that section for BEV vs ICE.
I do see the concerns though, you'd basically have to back-up into each charging station parking. But I supposed it's no different than reversing out of the charging station parking spot.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
12-21-2021, 12:34 AM | #4 |
Rep 92
Drives: E28 528i 1982 - G30 530e 2018
In Norway many companies make it manditory to back into a parking space if you park in their lot or if you work on construction sites and park there as a health and safety thing.
Its proven to cause way less fender benders/risk of backing into people or things when you back into a parking spot at arrival when you have the best overlook cars comming behind you etc.. When you put the front of your car first into a parking space you also dont have right of way when you are pulling out and that alone causes people to have accidents. 😂😄 |
12-21-2021, 04:50 AM | #5 | |
Rep 2,180
12-21-2021, 09:59 PM | #6 | |
Rep 133
12-21-2021, 10:21 PM | #7 | |
Rep 5,089
I am not sure pulling out of parking spot head first provides right of way in US/CA though .... |
12-22-2021, 06:24 AM | #8 |
Rainbow Racer
1008
Rep 2,539
exactly why a must have for me was the Parking Assistance Package. I have it on the current G20, the top surround view, the "augmented reality" with the outside perspective looking directly at the car from multiple angles, and the self-reverse feature based on how you drove it last made it an easy choice.
-Loe P.-
12-25-2021, 02:01 PM | #9 |
Rep 186
We have two chargers center-mounted in the garage. We just run one of the charging cords across the floor, and the car rolls over the thick cable day in and day out. Then we plug in easily. No issues and we've done this for several years. We may have to swap garage spots, though, for the easy of it.
12-28-2021, 07:02 PM | #10 |
Rep 568
Drives: 2019 X5, 2022 i4 M50
LOL…. It’s all consistently inconsistent between brands…and models.
BMW PHEV’s, front fender BMW BEV’s (i4/iX), rear fender (fuel fill) Audi/Porsche, front fender VW, rear fender (fuel fill) Tesla, rear fender Ford, front fender Rivian, front fender … you get the idea At least everyone, sans Tesla (in the USA) all use the same CCS connector.
Current: ‘19 G05 X5, '22 G26 i4 M50
Retired: F15 X5, F80 M3 ZCP, F10 535d, E84 X1, E90 335d, E92 335i, E46 330i, E39 M5 |
12-29-2021, 10:16 AM | #12 | |
Rep 4,210
12-31-2021, 04:40 AM | #13 | |
Rep 1,236
i4 would naturally use the rear opening, since the body panel with an opening is already there for ICE car. For PHEV, they have to look for another opening as the rear opening is occupied by gas tank refill. So this is not done by choice. |
12-31-2021, 11:04 AM | #14 |
Rep 2,180
There is no change - the i4 uses the existing gas tank lid as the charging port as there is no gas tank as in the 4-Series GC which shares its assembly line. No manufacturer will make a new panel stamping when there is one already made that fulfill the intended requirement.
12-31-2021, 05:45 PM | #15 | |
Rep 4,210
And lets look at some of the other changes. A tach that goes backwards. The start/stop button moved from the dash to the console. We spend lots of time developing muscle memory and then they change it without reason. |
12-31-2021, 06:00 PM | #16 | |
Rep 6,031
The rear quarter panel/aperture for a 4 GC already exists with a fuel filler opening. It is shared between ICE and BEV 4 Series vehicles. If that was not used, a new entire rear quarter/aperture would have to be stamped without the opening for the i4. Then, as any sheetmetal from a 5 Series is not compatible with a 4 Series, a new unique front fender would have to be created with an opening for recharging. Why would BMW do all this? I think your issue is the original location for the ICE fuel filler door, which led the overall 4 Series body exterior design program.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 12-31-2021 at 06:15 PM.. |
12-31-2021, 06:23 PM | #17 | |
Rep 2,180
Moving on, nothing to see in here. |
01-10-2022, 07:01 PM | #18 |
Rainbow Racer
1008
Rep 2,539
I actually prefer the start/stop on the center console. I hate the location behind the steering wheel on my F82, My B8.5 Audi S5 with its center console mounted start button made substantially more sense from an ergonomic perspective and I'm 100% glad BMW switched to this on the G-series, it's much more natural to be honest.
The i4 doesn't have a tach, just a power usage gauge, so the backwards tach isn't an issue on the i4. The Chinese market actually has a door on the front drivers side fender to accomodate the difference style charge ports there, so it has the standard rear panel port for the J1772 + DC fast charge in addition to the front fender one which has a Chinese market specific plug. The rear panel port is there as it's already part of the usual metal stamping
-Loe P.-
