12-11-2021, 08:37 PM | #1 |
Rep 195
I4 M50 - lowered?
I'm digging the i4M50 and considering it… how hard will it be to lower the thing? It's a 4x4 in its current state. The air suspension in the rear scares me.
I'm not worried about warranty issues regarding suspension or how long the dampers will last, so let's skip that ha ha. |
12-12-2021, 01:59 AM | #3 |
Rep 195
12-12-2021, 05:59 AM | #5 |
Rainbow Racer
1008
Rep 2,539
On any air suspension platform, including current BMWs, it's simply a matter of software, either a module to "trick" the default ride height, or coding a new default ride height.
So yes, the rears will be software, while the fronts will be shorter springs. In any case, we would have to wait for kits (software and hardware) to become available that will allow us to lower the vehicle. Last edited by spool twice; 12-12-2021 at 06:10 AM.. |
12-12-2021, 11:22 AM | #6 |
Rep 2,511
How is the ground clearance vs 'normal' cars?
Yesterday I took my son to visit Santa at a local farm/Lama experience... My standard F31 340i bottomed out on the track to the car park and the front air dam dragged. This was with the standard 15mm drop for MSport vs SE springs. Other family cars seemingly had no issues… With the battery slung underneath I will be very nervous of a standard i4 in similar circumstances. I thought I had read that the ground clearance of the i4 was already about 1" less than a similar 3 series due to the battery.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
12-12-2021, 12:30 PM | #8 | |
Rep 2,180
12-12-2021, 05:46 PM | #9 | |
Rep 92
Drives: E28 528i 1982 - G30 530e 2018
Im looking forward to seeing if this can be solved without ruining warranty first and foremost. Then the ride. Its for sure easy to get it lower with the rears being software like in the 5 series wagons we have in EU, and front being springs only. The impact of changing springs on the adaptive m suspension struts is not a thing i found a definitive answer to either as thats something people are already doing on other models. I have 5 years/200.000 KM warranty in Norway and it cant be screwed up as i will probably sell it in 3 years. But i want to fix the stance on this car abit.. My biggest problem with the look is the gaps, so from my thinking maybe more rubber is a better solution to the problem. Higher side walls etc. I have no idea but it seems like a better solution than lowering the car when the risk to the battery can be pretty big. Just a thought. |
12-13-2021, 12:44 AM | #10 |
Rep 253
The G26 BEV is only 6mm taller than the G26 ICE (1448mm vs 1442mm) so there's really nothing in it between the G26 i4 M50 and the G26 M440i ICE - their height and wheels gaps are virtually identical.
Changing overall diameter of the wheels and types will mess up the final drive ratio so you can't simply increase the type side wall size. |
12-13-2021, 01:07 AM | #11 | |
Rep 92
Anyone that has seen the i4 on a picture knows that it does not look like in the configurator btw. The gaps are way bigger. There is threads discussing the solution of using higher sidewalls to fix gaps on this forum where people have done it sucsessfully on xdrive 3 series etc. |
12-13-2021, 01:31 AM | #12 |
Rep 892
Drives: None atm
Yeah the wheel gap is kinda huge here is a picture from someone who posted earlier at a showroom. It is so huge at first i thought this one is standing on shipping blocks but geeeeh it really needs a lowering.
Current Car: Bicycle
Former Car:BMW i4 M50 Brooklyn Grey (MY22)| BMW i3s BEV (MY19)|Former Car: BMW X1 20d x-drive (MY16)|BMW m235i (MY14)|Former Car: BMW 120d (MY12)|Former Car: Volvo C30 T5 R-Design (MY08)|Former Car: Volvo C70 T5 (MY06)|Former Car: Volvo S40 2.0T(MY1999) |
12-13-2021, 01:51 AM | #13 | |
Rep 253
12-13-2021, 05:31 AM | #14 |
Rainbow Racer
1008
Rep 2,539
The M50 pictured above is definitely not standard ride height in the rear suspension, however it does show it is possible to just lower the rear end via programing.
how high the vehicle is from the ground to the center point up top is different than how high the vehicle is from the ground to the center point at the bottom since there is a battery pack. The i4 has a ground clearance of 4.9in, while the 4 series is 5.1in (approx 6 mm lower). So if the i4 is indeed also 6mm taller from the top center point, then that would tell me the battery pack sticks below the body 12mm, or almost 1/2in. Not bad to be honest, but yeah lowering any vehicle is a risk. Here are "normal" ride height M50
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
12-13-2021, 06:27 AM | #15 | |
Rep 2,511
A bit of checking and my sDrive F31 340i has a ground clearance of 140mm vs 125mm for the i4. So, 15mm or about half an inch of clearance lost. This shouldn't be an issue most days. Though, I may have to avoid that Lama experience again!… However, from my own experience above, 125mm it is notably less than most other family cars. Certainly something I will bear in mind. I guess this is why it gets air suspension! Keeps it level and trimmed when loaded up with family and baggage for a road trip. Both air resistance and ground clearance hits minimised. I have a M50 test drive next Tuesday. I may have to check I can get it on and off my drive! My driveway goes up and crowns onto the road…
12-13-2021, 07:08 AM | #16 |
Rainbow Racer
1008
Rep 2,539
Good point, I didn't even see the adults in that M50 to compress the suspension.
-Loe P.-
12-14-2021, 01:08 PM | #18 |
Rep 186
I don't know how BMW measures air spring ride height, but usually there's a little plastic arm that attaches to a sensor. A longer or shorter arm will adjust the height, though that can cause camber issues depending on the suspension.
Fronts would just need lowering springs or coilovers. You can probably take 1/2 to 1" off without significant issues. That seems to work on most cars. I'll see how it is with my first set of tires then consider going to a taller sidewall. |
