Forum for the entire range of BMW electric vehicles
BMW i4 Forum - i430, i440 (G26) EV Forum BMW i4 Forum - M50, eDrive40, eDrive35 (G26) EV Forum
      10-21-2021, 08:50 AM   #1
moff
moff's Avatar
Drives: X4M Competition
M Technology Pack on i4
So I am getting close to finalising a spec, and I noticed that after moving to the 19"s from the 20"s that I now cannot get the M Technology Pack which has better brakes and better battery cooling.
Anyone else noticed this?? So frustrating... might just have to order the 20"s and buy more narrow tyres for the wheels.
The pack detail:
....features increased heat capacity of the braking system and the cooling system that guarantees a long-lasting high performance under extreme driving conditions (similar to motorsport) (especially in combination with high outside temperatures). Includes upgrades for the drive train cooling system and the M Sport braking system.
Available with 20" 868 M Double-spoke Bi-colour Alloy Wheels on the M50 model.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey.
      10-21-2021, 08:53 AM   #2
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
Brakes probably don't clear the smaller wheels. Not uncommon.
      10-21-2021, 09:17 AM   #3
4monks
Drives: 2021 BMW M340i xDrive MHT G20
I'm not sure what the cooling is. I suspect this might be sadly a cut and paste from the MTech pack on other cars where there is an additional oil cooler. I've not seen anything on battery cooling.
      10-21-2021, 09:22 AM   #4
moff
moff's Avatar
I guess "Includes upgrades for the drive train cooling system" means battery cooling.
      10-21-2021, 09:31 AM   #5
lnaukkar
Finland
25
Drives: G30 530e, F40 118i
The drive train cooling is for 4 series, but for i4 that option is only the bigger front calibers and nothing else.
      10-21-2021, 09:49 AM   #6
moff
moff's Avatar
Thanks - that's good to know, although I now want the larger brakes
      11-02-2021, 06:29 AM   #7
Frans Jazz4ff
Drives: BMW I4 M50
The pack detail:
Strange, M sport braking system is standard in red or blue in the Netherland.
      11-02-2021, 09:01 AM   #8
techwhiz1
techwhiz1's Avatar
1856
Drives: E90 335, E70 X5
The pack detail:
The Tech pack gets larger rotors.
Arctic Metallic\CF Splitters,Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1\M-Performance Brakes\Cobb Tuned\xHP Flash ->
      11-13-2021, 08:18 AM   #9
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
M Technology package in the i4 is front 374mm rotors (348mm standard) and bigger 4-piston calipers.
Rich9600740.50
      12-08-2021, 01:00 PM   #10
jpuffmasterpuffpuffpuff69
Drives: Jaguar I-Pace
So there is no additional cooling for sure?
      12-08-2021, 01:06 PM   #11
Encanto
Encanto's Avatar
No… this “additional cooling” was a bad copy and paste from the 4-Series M Tech package.
      12-08-2021, 01:26 PM   #12
spool twice
Rainbow Racer
spool twice's Avatar
Drives: BMW M4cs
2019 M4cs  [0.00]
seems like this package was recently renamed....now it's called "high performance tire package"...at least in the US.
The brakes should be the same as the M340/M440i, which are M-sport brakes but not as large as the M-performance accessory brakes.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ]
Current Car: F82 M4cs | TT-RS | On Order: i4 M50
      12-08-2021, 04:41 PM   #13
mbchris
Drives: Volvo S90
I ordered 3FW 20" wheels. 33T M technology package added at no cost. USA build.
      12-08-2021, 05:01 PM   #14
Encanto
Encanto's Avatar
The M Technology package brakes are the same as the M Performance brakes -up-sized calipers, 374mm rotors- except that the M Performance rotors are dimpled and slotted.
      12-08-2021, 05:10 PM   #15
spool twice
Rainbow Racer
Drives: BMW M4cs
2019 M4cs  [0.00]
Makes sense, BMW has just been vague about what actually is part of the i4 package. It doesn't indicate larger brakes, just 33t, which can be different depending on series/model.
The larger brakes could possibly be the other reason why going from 18 to 19" wheels is seems to only be a 25 mile range hit on the edrive40, but going from 19 to 20" is almost double the range hit on the M50 because of the heavier brake hardware.
-Loe P.-
      12-08-2021, 09:20 PM   #16
Wider, stickier, heavier tires probably cause most of the drop when going to the 20" wheels. Brake weight has little impact on fuel economy since it's all closer to the hub. Calipers aren't spinning, too. The wheel and tire weight matter more. I guess it all adds up.
The new text on the US website is:
"High Performance Tire Package
$2,500
Enhance the aggressive appeal of your vehicle with a body-colored rear spoiler, increased braking capacity for extreme driving conditions, and wheel arch moldings on the rear axle. Also included are wider, high-performance tires offering improved traction, reduced stopping distance and enhanced dynamic response."
Nothing about cooling anymore.
So is 2500 worth it for upgraded calipers and massively upgraded wheels and tires? If you want better handling, I'm guessing a huge yes. Braking doesn't matter so much because it's an EV, but extra capacity is a good thing.
      12-08-2021, 10:17 PM   #17
techwhiz1
techwhiz1's Avatar
1856
$2,500
I went for it just for the wider wheels and brakes.
My mileage requirement is 250 so anything extra is a plus. Also I suspect in Eco mode mileage will be better. I think, and don't quote me, the front motor is not engaged for drive in Eco mode. Since it also doesn't have permanent magnets it should freewheel with out a lot of losses.
      12-09-2021, 07:34 AM   #18
Haywood
I know a thing or 2 about a thing or 2...
Haywood's Avatar
3101
Drives: E36 M3 Coupe, e39 M5, i3s
2003 BMW e39 M5  [0.00]
1997 BMW e36 M3  [0.00]
$2,500
Interesting when you scroll down on the package, there's this:
Increased capacity of the braking system for improved performance under extreme driving conditions, particularly when driving in very high temperatures.
Doesn't mention cooling per se, but it does say improved braking under high temperatures.
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1
1997 Alpine White e36 M3 (the old gal)
2013 Mineral White e92 M3 (sold )
2014 Carbon Black 650i M-sport (sold)
      12-09-2021, 10:38 AM   #19
It might mean some kind of ducting. It definitely refers to the increased capacity of larger discs, calipers, and possibly pads.
I'll likely use one-pedal driving 95% of the time.
Haywood3100.50
bmw
