BMW M3 and M4 - The Icons
home
Technical Sections Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      10-05-2021, 04:35 PM   #1
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
▀▄ eas | DIY: S58 M3/M4 BMC Filter Installation
BIMMERPOST
     Featured on BIMMERPOST.com
A panel air filter is commonly referred to as a replacement air filter. It is installed in the vehicle's original airbox to replace the OEM air filter. It is made of high performance materials that allow for an increase in air flow along with more efficient filtration. These BMC filters guarantee containment of all impurities from as small as 7 microns, as compared to the OEM's 10 microns.
The OEM intake system is very good from factory and leaves very little to be improved upon, other than filtering media which consists intake air flowing past (2) sets of filters, one paper and one charcoal.
Filters contribute to generally any gains claimed by aftermarket intakes, at a much lower entry point delivering approx ~10whp and slightly more spool noise from the turbos and can be installed in about 20 minutes. BMW airboxes are generally fantastic in stock form and not at all restrictive for normal street power levels - but the filtering media can be definitely improved upon.
BMC air filters are produced using a full molding system that enables the characteristic red filter to be realized from a single mold with no welded joints, thus avoiding easy breakage. The rubber used in BMC air filtering systems has a long life, is very durable and has optimum adhesion characteristics to all shapes of airboxes. BMC filters are made of a multi-layered cotton gauze soaked with low viscosity oil covered with an epoxy coated alloy mesh to ensure protection from petrol fumes and oxidization due to air humidity. All BMC air filters are pre-oiled, and they can be washed and regenerated by using an appropriate regeneration kit.
BMC Filters are compatible for both S58-equipped G8x M3/M4, including Competition/XDrive.
Installation
BMC S58 High Performance Replacement Air Filters (set of 2)
https://europeanautosource.com/bmc-h...r-filters.html
Tools needed
T25 Torx driver
Pocket screwdriver
13mm & 16mm Wrench (socket)
Installation
1. Remove Strut Tower bolt (13mm forwardmost bolt, 16mm nuts on top of strut tower)
2. Remove Strut Tower Brace
3. Remove T25 torx screws from stock airboxes (4 each airbox)
4. Repeat on passenger side airbox
5. Remove airbox lid
6. Remove charcoal liners with a pocket screwdriver (removed in photo) and discard. Repeat on passenger side.
7. Remove stock air filters and discard. Repeat on passenger side
8. Install new BMC filters into place, filters are marked for left and right sides
9. Reinstall filter lids
10. Reinstall strut tower brace and enjoy your newfound power
Torque Specs
Airbox: Snug to fit/hand tighten
Strut tower brace
18-20lb-ft.
Enjoy! Feel free to respond to the thread with any questions.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
///AVM2529.50
savi01134.50
mathys202.50
rz9990.00
      10-05-2021, 05:16 PM   #2
vetteflier
Drives: 2021 BMW M4 Competition
Can you just lift the airbox top off, or do you have to loosen the clamp at the hose?
      10-05-2021, 05:37 PM   #3
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
You are able to lift the lids to gain access to the filters without removing the intake tracts - but you can remove the lid also, it's only held on by a single worm-type clamp.
      10-05-2021, 05:48 PM   #4
Ghozthunter
Eleet Tech
Ghozthunter's Avatar
Drives: a bimmer
What is the purpose of removing the strut brace? I've removed that top of those air boxes to get those carbon filters off without removing the brace.
GixY2K517.00
      10-05-2021, 05:57 PM   #5
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
We find it's much easier to access underneath the lids with the brace removed. Only takes a couple of extra minutes.
      10-06-2021, 11:36 AM   #6
RyanBMW
RyanBMW's Avatar
Drives: 2008 E92 328i, 2011 F10 550i,
Can we get some new gloves for the job? They got everything dirty for such an easy job!
      10-06-2021, 12:17 PM   #7
Poffman
Drives: 2010 M3
Will this fit 22 X3M competitions?
      10-06-2021, 12:21 PM   #8
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Part surfaces are always wiped down after work is completed, meaning cars leave cleaner than when they arrive.
X3M & X4M have a different airbox, which uses 4 filters instead of 2.
Poffman493.00
      10-06-2021, 03:01 PM   #9
alphawawa
Blue Blood
alphawawa's Avatar
Drives: 2005 BMW M3 Coupe/TiAg+IR/6MT
Can we see some before and after dyno runs?
Rob
C : 2005 BMW M3 / 2013 BMW X3
P : 1969 VW Beetle / 1989 BMW 320i / 1991 BMW 318is / [a ton of BMWs between 99 and 2012] / 1991 Porsche 944 S2
      10-06-2021, 04:23 PM   #10
535i MSport
535i MSport's Avatar
Drives: 2017 C63S T
That's a great suggestion!
2017 M3 Comp Pack 450PS
2017 C63S T 510PS
      10-06-2021, 05:04 PM   #11
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Didn't dyno after this install, but expect results to be about the same ~10whp we see on the S55.
      10-06-2021, 05:43 PM   #12
NightWriter
NightWriter's Avatar
4844
Drives: G80 M3 Pure
Any references/links to S55 results?
I'm generally skeptical that an air filter replacement can realistically deliver meaningful increases in output. (If it were so cheap and easy, why wouldn't the manufacturer do it from the factory?)
alphawawa190.00
      10-06-2021, 06:17 PM   #13
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
This falls under the "engineers vs bean counters" category. But you will see them in race/high performance environments, including Formula 1 & Le Mans.
You can see links to S55 dynos here, as the DME is making incremental gains from each run: https://f80.bimmerpost.com/forums/sh...1#post16507069
The paper/charcoal liners are due to emissions requirements, while the gains are contributed to a combination of having freer flowing media (oiled gauze) and elimination of the charcoal filters, with a small amount of turbo spool noise thrown in. Also the added bonus of never having to purchase filters ever again, as the filters can be cleaned and reoiled every 12K-15K mi.
      10-06-2021, 07:00 PM   #14
Delmoney335
Delmoney335's Avatar
915
Drives: 2021 BSM G80 comp
2015 BMW M4  [0.00]
2012 BMW M3 Coupe  [0.00]
Can we just remove the charcoal liners and keep stock filter ? Does that do anything
2021 G80 Comp
      10-06-2021, 07:41 PM   #15
ShockArrival
ShockArrival's Avatar
Drives: G80 Search
2014 BMW M5  [0.00]
BMC FTW!
Solid DIY write up.
Hunting for a G80 | 997 911 C2S AS/Blk 6MT SC SOUL
tom @ eas8216.50
      10-06-2021, 09:09 PM   #16
Roch M4
I /// M FAN
Drives: M4 SS/SO 2016 / X5M C 2023
The size and shape of the filters looks quit similar to the one's from S55 M3 and M4
      10-06-2021, 09:38 PM   #17
Jaguar
Mark 42
Jaguar's Avatar
1051
Drives: M
This was my car in the shots and I was literally blown away by the difference the BMC made. When I drove home, I forgot I had the filter installed (mainly focusing on my new springs EAS installed). Once I got to the freeway on-ramp and hit the gas hard in 2nd gear, the car fishtailed while traveling in a straight line. I've put 6k miles on the car and it's never done this before the filter install. Never. During a turn-yes, but not traveling straight. I replicated this 3 separate drives again and just can't believe the added bump in responsiveness this filter gave the car. More midrange sound as well which was not present before.
tom @ eas8216.50
Ibiza3612.50
      10-06-2021, 10:32 PM   #18
ihbase
Drives: e90, e91, f31, f87
Any proof?
-Michael
      10-06-2021, 11:45 PM   #19
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
It should, but paper filters are still restrictive over cotton-gauze.
Similar, but different enough to warrant a new part number
Originally Posted by ihbase View Post
Any proof?
-Michael
Haven't had a G8x on the dyno yet, but anyone in the area is more than welcome to drop by and schedule one. I'll be more than happy to share results.
      10-07-2021, 12:41 AM   #20
Peertwelve
Peertwelve's Avatar
No_Country
781
Drives: Silverstone E92 M3
2008 BMW M3  [3.00]
Thanks for the link Tom. On that F80 post you said
While gains are minimal on a relatively stock engine, these will be prove more beneficial once more performance parts are available, such as tunes and exhaust. A bonus is a mild amount of turbo spool noise during revving.
I read that as "a tuned car will produce more with the reusable BMC filter". But above you mention 10hp. Is that gain expected on a stock G80?
2008 SSII E92 M3 | LCI CIC, Apps, Tails| MPE | BBS Ch-R
1990 325i
Sold- 2011 335i Sedan | 6MT | Wavetrac | Eibach Pro | CDV delete | Cobb | BSW
Sudden death - 1970 BMW 2002
alphawawa190.00
      10-07-2021, 10:52 AM   #21
hellokitty
hellokitty's Avatar
Drives: '17 M3 ZCP DCT
BMC filters should produce gains on a stock vehicle. Here is the S55 dyno.
Bigger gains are to be had when tuned obviously.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
tom @ eas8216.50
      10-07-2021, 12:23 PM   #22
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Yes, S58 is very similar to S55 (flame suit on). Simple fact - more air = more power.
Tags
bmc, cotton gauge, eas, filter, intake
g80
