09-22-2021, 09:22 AM | #1 |
Rep 402
Feedback request - Base owners running piggybacks?
Morning all!
In aims of a concise resource for future 6MT owners, I thought I’d request a roll call style feedback request from anyone who is currently or has ran a piggyback on G8x base. There are 2-3 anecdotal testimonies, but rather few & far between at this point in regard to base.. Don’t we all deserve torque here? Pros, cons? Pro racechip or JB4? Is it as simple if looking to run corn go JB4, and if running 93 and want a “set & forget mod” go racechip? Thanks to all in advance! |
09-22-2021, 12:08 PM | #3 |
Rep 402
LongBeachDinanFan thank you for your feedback! I ran JB4 10+ years ago, just having a hard time pulling the trigger this time I suppose.
Intent would be to keep car on pump gas if that is beneficial for anyone else’s anecdotes Cheers! |
09-22-2021, 01:21 PM | #4 |
Rep 508
Maybe find a deal on a used RaceChip if you just want to add a few hp? I'd never buy a new one cause they drop like 50% as soon as you install it. On the F90 JB4 you had the option to install only the two boost sensors and then it would act like a RaceChip but at least you had the option to connect the rest later if you wanted and retained its resale value. I don't know if the G80 one does that but worth checking.
mattburks750.50 |
09-22-2021, 07:08 PM | #5 |
Rep 477
Having a great time with the JB4 on my Base. Really wakes the car up. Makes the redline draw out just that much more intense. Low end feels about the same to be honest but the mid and top end is just wow. I daily map1 with 91 and haven't had a chance to run E30 but it is on my list. For full effect of this car it really needs the boost levels brought up. The ECU adapts so well with the jb4 it's almost seem less. I've ran JB4 on all my BMWs.. F80x X3m40i, X7, F90 … they all benefit.
09-22-2021, 08:40 PM | #6 | |
Rep 148
Really the low end feels the same? I was expecting that maybe it will wake it up a bit there, but well, kind of make sense, larger turbos, takes time to spool them. I do wonder if the M4C also feels weak in the low end. |
mattburks750.50 |
09-22-2021, 09:20 PM | #7 | ||
Rep 477
No Downpipe. Just like the F90 platform it's not necessary. Plus it makes these cars sound just straight terrible to me. I was able to achieve 10.3x with my F90 with just race gas and jb4. I'd suspect it's no different on this platform. |
09-23-2021, 09:16 AM | #8 |
BimmerPost Supporting Vendor
24206
Rep 190,807
I have been running Race chip on my personal M4 Comp for a few months and im very happy with it. Lots of power without any issues.
https://g80.bimmerpost.com/forums/sh....php?t=1856506 I will be trying the Jb4 soon since i have access to E85. Im expecting to not have any issues either and make even more power with the better fuel i will be using
Check out our current sale by clicking on this link!
https://x-ph.com/sale/ Phone number 702-494-9435 |
mattburks750.50 |
09-23-2021, 10:40 AM | #9 | |
Rep 111
edit: Bah this is for a comp. Still zero real world information on base M3s available it seems. |
09-23-2021, 11:06 AM | #10 | |
24206
Rep 190,807
Once I post the Jb4 thread , I will also include a datalog of the dyno run.
09-23-2021, 12:17 PM | #11 |
Rep 111
I mean it's still great that you posted dynos that show map and fuel. Just wish somebody would post these for base.
Racechip claims they developed for use with the base M3, but show no data. Did they simply not log any dynos? Either they didn't log dynos or they simply aren't sharing the information. I'm not sure which is worse. But I can tell you it's why I have yet to order one. Both companies are really quiet when it comes to specifics about the maps and the recommended fuel types and the expected gains. JB4 at least publishes a map guide (on their forums, not as part of the product docs) but even when I ask them directly about boost targets and how they relate to the base m3 I get basically a non-answer and a response of "we'll need to see a log (after you purchase, install, and dyno our product)" Like, I'm an engineer so I believe in doing the due diligence when it comes to product specs. If a customer were to ask me "How will your product perform?" and my response was essentially "No idea, how about you buy it, deploy it, and then you tell me!" I'd get laughed out of the room. |
09-23-2021, 02:03 PM | #12 |
Rep 402
Circa77
Well, took the plunge. Going JB4 + Bluetooth. Install scheduled for Tuesday with AST springs & Macht Schnell spacer set. Will be a good day, and will report back with data as I’ll have logging capabilities. |
kingmonkeyjr454.50 |
09-23-2021, 11:46 PM | #13 |
Rep 32
I'm very happy with the Jb4 so far. Added mid range tq lights up the tires in 2nd gear now. Pulls harder all the way thru the rpm range. I'm running my own custom map 6 for 93 fuel and results are very pleasing, almost a 3 second improvement 60-130mph
translux481.00 |
09-24-2021, 04:41 AM | #14 |
Rep 193
1/4 times ?
09-24-2021, 08:39 AM | #15 |
Rep 735
I'm a fan of the JB4, have been since it was JB3 10+ years ago. I wouldn't hesitate to go that route while waiting for flashing to be widely available. I can't imagine JB4 and race chip are that far apart in terms of power output potential, but who can chime in on driving feel during times when you're not hooning it? Does either do better as far as retaining the stock smoothness when driving casually? Jerkiness on/off throttle and any hesitation from the piggybacks? That's the feedback I'd be looking for right now.
Adding: this question is specifically for MT. Because typically the early development is focused on AT cars, making sure they shift well and drive smooth. MT gets second priority in this area it seems, which isn't too surprising since there's just less of them. Last edited by Indo Rider; 09-24-2021 at 08:48 AM.. |
mattburks750.50 |
09-24-2021, 08:46 AM | #16 | |
24206
Rep 190,807
Power is not that different between Jb4 and Race chip unless you are using E85 or race gas. the Jb4 has maps for higher octane including a custom map, Race chip does not
09-24-2021, 09:25 AM | #17 | |
Rep 508
09-25-2021, 12:24 AM | #19 | |
Rep 32
G80SWFL74.00 |
09-25-2021, 09:50 AM | #20 |
Rep 508
Use the JB4 to lower boost during launch in 1st gear, it's a setting in their app. I used it on the F90 to reduce wear and tear on the transmission in launch mode.
09-25-2021, 10:48 AM | #21 |
Rep 32
Yep doing that already feels much better with a -5lbs reduction in 1st. I'll have to find some clear roads and get in another run now
09-25-2021, 01:59 PM | #22 |
Rep 402
