08-03-2021, 05:19 PM | #1 |
Rep 711
Achilles Heel of the G8x
Anybody have any ideas what it may be? We know with the E9x it seemed to be the rod bearings, and in F8x it was the crank hub closely followed by the TMIC leaking. Anybody have any ideas or already seeing the same issue across multiple G8x cars? Maybe we could even keep tabs on reoccurring issues early so BMW could possibly address it. Just curious!
08-03-2021, 05:30 PM | #2 |
Rep 615
IMO, the controversial front end , transmission (no DCT) , and weight. None of which personally bother me.
08-03-2021, 05:49 PM | #3 |
Rep 711
08-03-2021, 06:34 PM | #4 | |
Rep 1,286
BMW has managed to chronically f*ck something up with every generation.
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
PLife647.50 IND-Distribution9587.50 |
08-04-2021, 08:56 PM | #5 |
Rep 711
08-05-2021, 10:10 AM | #6 |
BimmerPost Supporting Vendor
24206
Rep 190,807
BMW record is not that bad actually, the B58 and N55 have been very reliable.
Check out our current sale by clicking on this link!
https://x-ph.com/sale/ Phone number 702-494-9435 |
08-19-2021, 01:56 AM | #7 |
Rep 2,160
08-19-2021, 06:43 AM | #8 | |
Rep 109
08-20-2021, 06:01 AM | #9 | |
Rep 430
Every issue is exacerbated when the car is modded and driven hard.
2022 M3 xDrive - BSM/Tartufo
08-23-2021, 11:47 PM | #10 |
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Anyone else concerned with the fact that there are no bushings on the rear subframe? Asking as an e46 m3 owner .
08-24-2021, 06:50 AM | #11 | |
Occasionally frequent poster
3000
Rep 2,744
And BMW is not alone. We know all about them, as Bimmerphiles, but Porsche (generally recognized as one of the best engineering car companies) has had many different engine issues including bearings, seals, cylinder liners and fires, Mercedes are often regarded as money pits and of course Audi, which makes great cars that are in the shop almost as often as Maseratis. GM's premier performance car, the Z06 Corvette, often cannot survive a day at the track without overheating and going into limp-home mode, and if you spend a few hours on a Mustang forum you'll see that those guys have to spend thousands to rectify design issues that still exist on a nearly 60 year-old platform.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
08-25-2021, 05:16 PM | #12 |
Rep 12,310
Where on earth do you get a $4k job from? I was the one that wrote the DIY for it, and it's a couple hours job, and the whole part replacement is $1k. Hardly a fortune when it comes to older M maintenance.
08-25-2021, 06:04 PM | #13 | |
Rep 109
Blank
09-02-2021, 02:06 AM | #14 |
Rep 3,726
Probably the same issues as every other bmw dating back to 2006 when the first N54s rolled off the line, but not as bad as before as my modem BMWs are much more reliable compared to my older ones. High mileage will result in similar repairs I suspect.
- Valve cover cracking - Oil filter housing gasket leaking - Failed / leaky Injectors - Fuel pump - Water pump - Intercooler leaking - Oil cooler getting smashed when hitting debris on the road - Random sensors around the car failing due to age - Oil pan gasket / leaks
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
JDUNITNOW3525.00 |
