06-23-2021, 04:50 PM | #1 |
Rep 193
RaceChip G80 M3 issue
Hello,
Recently i installed a racechip piggy back to my g80 m3. Initially results were good, went from a 9.3 60-130 to a 8.1 - all is well. Did a couple more pulls and noticed acceleration dying at 128, re did the draggy same conditions and 60-130 became a 9.4, it almost feels like it's pulling timing. This is Map 7, could anyone help me resolve this?
Hadi
06-23-2021, 06:18 PM | #2 |
Rep 2,067
@r33_RGSport
r33_RGSport12972.00 |
06-23-2021, 07:05 PM | #3 |
Rep 67
I'm curious to find out as well! Just received the RaceChip and waiting to install..
The Dream is free, the Hustle is sold separately.
06-23-2021, 11:46 PM | #5 |
Rep 193
😂, kinda new to having a bmw. Is this legit? What would that do
Hadi
06-24-2021, 01:22 AM | #6 | |
BimmerPost Supporting Vendor
12972
Rep 18,717
Not sure if you purchased it from me or directly. I will try to help you as much as I can, but if you purchased directly, I will only can do so much. Please explain more on what and how did you do it. Your gas octane, etc. Which map are you at? Warm up timer setting, etc.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
06-24-2021, 05:13 AM | #7 |
Rep 494
That sucks man, hopefully its not misfiring. Curious as to what rpm is this happening at? Is there a shift delay or is the car cutting power in gear? Looks like map 7 may be too much juice under these conditions have u tried map 6? Any error codes stored in the ECU?
06-24-2021, 05:50 AM | #8 |
Rep 494
Just did the math top speed in 4th gear is 139. Thats smack in the middle of 4th gear (between 115-120 mph on your dragy). Its pulling power the G’s drop to zero.
06-24-2021, 06:39 AM | #9 |
Rep 193
This is exactly what it feels like, like it's cutting power. I just think the boost is too much for the ecu. Good eye on that
Hadi
06-24-2021, 06:41 AM | #10 | ||
Rep 193
Hadi
06-24-2021, 06:43 AM | #11 | |
Rep 193
Hadi
06-24-2021, 06:49 AM | #12 |
Rep 494
06-24-2021, 08:18 AM | #13 |
Rep 193
What's the fix
Hadi
06-24-2021, 08:22 AM | #14 |
Rep 494
No idea. I would scan the car and see whats up before re running it. If no codes present i would try map 6 as it came from race chip.
Also try and use shell 93 and make sure not to refuel while the tankers are refilling the staton. My guess is either bad gas, misfires, or you hit the torque limiter in the trans. Last edited by PLife; 06-24-2021 at 08:28 AM.. |
r33_RGSport12972.00 Hadib233125.50 |
06-24-2021, 09:25 AM | #15 | |||
12972
Rep 18,717
If you are, something with the car. Need to scan, try new fresh of gas, check any loose connection, etc. This new cars with all electronic sensors, will act stupid just for a simple thing.
06-24-2021, 09:26 AM | #16 | ||||
Rep 193
Hadi
06-24-2021, 09:30 AM | #17 | |||||
12972
Rep 18,717
06-24-2021, 09:32 AM | #18 | ||||||
Rep 193
Hadi
06-24-2021, 09:39 AM | #20 | |
Rep 10,166
Have you tried an uninstall reinstall? Just thinking here as I have no idea whats happening with your exact situation. Where or who did you get the RC from? Maybe they can help and reach out to RC Germany... might need some data logging.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
06-24-2021, 09:42 AM | #21 | |
12972
Rep 18,717
Gotta ask Vic55 if he can test it. He has the car. I never have that issue on my X3MC, which has the same tranny. I assume all up to optimal temp when you did a pull, right?
06-24-2021, 09:54 AM | #22 |
Rep 10,166
Op let me know what you would like me to do and Ill take my car out right now and report back.
