BMW M3 and M4 - The Icons
home
Technical Sections Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      04-25-2021, 06:06 PM   #1
35mphgolf
Drives: ‘18 Macan Turbo
Ethanol-free gas?
I presume it’d be best to run ethanol free gas if available? I found this site and it appears to be updated (though it’s v outdated). Could there be any danger to always running E0 gas?
https://www.pure-gas.org/
      04-25-2021, 08:23 PM   #2
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
There isn't much danger running ethanol free gas but there isn't a benefit either.
      04-27-2021, 09:23 AM   #3
gpdriver17
Drives: F90 M5
How did you come to that conclusion? Everyone loves ethanol. Even without a tune, your car will run better with it. I don't have a tune and add 5-10 gallons of E85 to every tank. No issues. Worst case you won't get quite enough fuel in the engine and you'll feel it cut power. Then you know to back off a few gallons of ethanol.
2018 BMW M5
2018 Porsche GT3
2023 Porsche Macan S
2023 Porsche 911 Turbo S
      04-27-2021, 04:14 PM   #4
35mphgolf
Right that’s what I’m saying. Ethanol is just corn juice, not gasoline. The engine will make the most power on gasoline I presume. I remember when they started adding ethanol to gas, cars had issues and were underperforming. Are these new engines designed to not care either way? What’s the manual say about ethanol gas?
      04-27-2021, 08:58 PM   #5
Nkr15
Nkr15's Avatar
Drives: 2021 M3
Ethanol burns cooler and it is the single cheapest and best mod to make power in any car. I wouldn't recommend going over e20 without a tune but the more ethanol you run the more power you will make. Regular pump gas is about e10. I have ran a e60 tune and swapped out my fuel pump and used a flex fuel sensor that was tuned to regulate the fuel properly.
      04-28-2021, 11:07 AM   #6
35mphgolf
ok gotcha. Did not know that. Good to hear.
Nkr151123.50
      04-28-2021, 12:01 PM   #7
Nkr15
Nkr15's Avatar
Drives: 2021 M3
Here is an example of what the G80 is capable of on the E85:
https://www.bimmerpost.com/forums/sh...php?p=27496806
g80
