BMW M3 and M4 - The Icons
home
Technical Sections Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      04-25-2021, 12:30 PM   #1
vetteflier
Drives: 2021 BMW M4 Competition
Fuse to keep exhaust baffle open?
Just got my '21 M4 Competition and love it! In my Corvettes, there was a fuse you could pull to keep the exhaust baffle open at all times. Is there one in the M4? First time BMW owner, really enjoy the forum and information. Lots to learn!
Thanks
      04-25-2021, 12:54 PM   #2
Sbm007
Sbm007's Avatar
Drives: G80 M3CX (Oxide Grey)
Thanks
On the older F8X, you could simply unplug each of the 2 valve controllers near the exhaust and that would leave the exhaust flap open at all times. Might be similar for the G8X - not sure!
Gone:
2011 E90 318d (Alpine White) • 2016 F83 M4 (Mineral White) • 2019 F83 M4 Competition (Sapphire Black)
Current:
2022 G80 M3 Competition M xDrive (Oxide Grey)
      04-25-2021, 09:25 PM   #3
acre22f90
acre22f90's Avatar
529
Drives: 2024 X5 xDrive40i
Thanks
Does the exhaust button not accomplish this? I know in my g20, you had to actually drive in sport/sport+ for the valve to be open, but I figured the exhaust button would solve for any need in doing this.
Current: 2024 X5 xDrive40i Carbon Black/Tartufo
Previous: 2021 M5 Competition MBB/Black, 2021 M3 Competition Tanzanite/Tartufo, 2021 M340i Dravit Grey/Cognac
coreyjn7230.50
      04-25-2021, 09:42 PM   #4
coreyjn7
coreyjn7's Avatar
Australia
231
Drives: 2023 M240i
What he said ^, just press the button
      04-25-2021, 10:48 PM   #5
Ghozthunter
Eleet Tech
Ghozthunter's Avatar
Drives: a bimmer
I have a g20 and even on sport + the valve opens and closes depending on the rpm. Ended up disconnecting it. Not sure about the g80 or g82 since it actually has a button for it.
      04-26-2021, 01:53 PM   #6
TrentMeister
TrentMeister's Avatar
2860
Drives: g82 comp
The button still closes the valves at a bunch of random times.
      04-28-2021, 12:58 PM   #7
vetteflier
That's what I've seen, and on my '18 Vette, pulling the fuse kept them open all of the time, otherwise they would close at certain constant speeds even in Track mode. Youtubes have shown how to disconnect the plug/s. Just have to do it with valves open. Older one used vacuum, not electric to operate the valves. Same idea--pull and plug the hose.
      04-28-2021, 06:27 PM   #8
acre22f90
acre22f90's Avatar
529
Is there a plug into exhaust near the end? On the g20, the right exhaust tip/muffler had a plug that electronically controlled the flap. Once unplugged after it was open, it would prevent it from closing.
      05-01-2021, 10:00 AM   #9
TrentMeister
2860
Drives: g82 comp
I unplugged mine the other day and was suspicious that there was some fail safe that closed them after I unplugged.
So I plugged em back in.
      05-01-2021, 10:32 AM   #10
acre22f90
acre22f90's Avatar
529
So there is a plug? What made you suspicious? If like the G20, there would be no way for it to close without the electronics.
      05-01-2021, 12:16 PM   #11
TrentMeister
2860
Drives: g82 comp
It just didn't sound louder, the plugs are super easy to get to and un plug.
Once my cars back from ppf I'll mess with it more.
      05-02-2021, 01:17 PM   #12
vetteflier
Unplugged the left connection yesterday. But, the valve stayed only partially open. It seems if the flaps are fully open, you can unplug and they will stay. But tried half a dozen different times to get them fully open and couldn't. Plugged it back in and will ask my tech at the 1200--1000 for me, service if he can keep them open all of the time. Much easier in the Vette, and I would think there would be a fuse that killed the connection, but again, will the default be full open is the question.
      05-02-2021, 02:27 PM   #13
TrentMeister
2860
Drives: g82 comp
I think I'll need someone in the driver seat giving it some throttle while I pull the plugs
      05-02-2021, 02:36 PM   #14
vetteflier
That may work.
      05-02-2021, 07:26 PM   #15
acre22f90
acre22f90's Avatar
529
Or maybe upon cold startup? Aren't they wide open for that?
      05-02-2021, 07:31 PM   #16
jonahk
jonahk's Avatar
Drives: 2021 G80 M3
2021 BMW M3  [0.00]
2018 Porsche Macan  [0.00]
2018 BMW M2  [0.00]
Didn't the //M engineering video talk about how this isn't a binary valve any more (off/on) and now it's variable?
Trying to wrap my head around robbing the car of some back pressure when the ECU calls for it by leaving the valve stuck open at this point.
      05-02-2021, 07:33 PM   #17
TrentMeister
2860
Drives: g82 comp
That's what I tried and it seems like it somehow closed them back up
      05-02-2021, 11:11 PM   #18
Ghozthunter
Eleet Tech
Drives: a bimmer
It's a shame the m440 sounds louder than a m3 or m4.
      05-03-2021, 06:34 AM   #19
FISH22
FISH22's Avatar
Drives: G80 M3 Competition
2021 BMW M3C  [10.00]
2011 BMW M3  [10.00]
Like mentioned above, it doesn’t seem to be an on/off. I’ve noticed a few different exhaust notes... standard with nothing enabled, then pressing the exhaust button, then a tad louder once I press the M1 or M2 button. Is this all in my head, or does the exhaust get even louder even after pressing the exhaust button on the center console?
      05-03-2021, 08:56 AM   #20
moproblems
Beware of cheap bait!
moproblems's Avatar
709
Drives: 2021 M4 Isle of Man Green
M sound control off is the valve always closed no matter the programming. The engine mode determines how open the valve goes with M sound control on.
      05-04-2021, 12:05 PM   #21
vetteflier
It appears to be variable, whatever the ECM is calling for. Interesting about back pressure, as this is a turbocharged car. Vette was never an issue. I don't think it would be a problem, as two pipes are muffled all the time. However, I'm not an expert on back pressure with respect to turbos.
      05-04-2021, 12:18 PM   #22
Ginster6
Drives: G87 with a Stick
LOL... My wife 2021 x3m40i with fused pulled. is louder than my M3 at sport+. at cold start. and on the roll...
some how those B58 motor sounds very good.
g80
