BMW M3 and M4 - The Icons
home
Technical Sections Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      04-14-2021, 01:00 PM   #1
TrentMeister
TrentMeister's Avatar
2860
Drives: g82 comp
Anyone cut out secondary cats or resonators yet?
This thing is way to quiet.
It's making me miss the sound of the s55.
Update: I pulled both resonators(incredibly light) and had an xpipe put in place and damn...
The sound is 100% how it should have come from factory.
Super smooth, throaty, and has a nice ascending pitch as you move through the RPM's.
It's not loud but adds volume to the entire rev range giving you some much needed sports car sound.
I paid 200$
Here's a few videos my woman took for me.. I'll get a better comprehensive set of videos soon.
The video's with the standing revs should have just been 1 but it cutout for the majority of the midrange.
Notice 0 rasp at top end.
Also the footage is dramatically better with headphones
https://youtube.com/shorts/RSS839HpbnQ?feature=share
https://youtube.com/shorts/Q8QxKT7GcZA?feature=share
https://youtube.com/shorts/JpqEJpkXr1E?feature=share
https://youtube.com/shorts/pngaygILHkk?feature=share
https://youtube.com/shorts/0Zy65tl54vw?feature=share
Appreciate 7
F85MTuNED1620.50
VonB1119.00
jermoni96139.00
BMWM4CX281.50
Seandale520.00
      04-14-2021, 01:33 PM   #2
jonahk
jonahk's Avatar
Drives: 2021 G80 M3
2021 BMW M3  [0.00]
2018 Porsche Macan  [0.00]
2018 BMW M2  [0.00]
Not affiliated with them in any way, but Valvetronic has a mid pipe in development for the G8x:
RugbyBro7601.50
      04-14-2021, 06:38 PM   #3
TrentMeister
2860
Drives: g82 comp
Yeah I saw that,
But if I can just go down to a exhaust shop and have them cut out the secondary's and the resonator so it's just straight through pipes and get a good sound..
I'd do that for sure..
It seems like I may have to be the guy to take one for the team and see how it sounds myself.
F80SRT695.50
weidake472.50
hamzag20557.00
702RIP12.50
      04-15-2021, 02:47 PM   #4
weidake
weidake's Avatar
473
Drives: 2021 BMW M3, 2017 Ferrari 488
Yeah I saw that,
just delete the resonator should do the trick. Deleting both 2nd cat and resonator may give you bad drone. Please let us know how it sounds
      04-15-2021, 03:46 PM   #5
TrentMeister
2860
Drives: g82 comp
Yeah I saw that,
Will do, I'd like to get some volume out of it for cheap..
hopefully bmw set us up for success with just some deletes.
I'll get some nice underside shots for everyone too once we get it on the lift.
      04-15-2021, 03:54 PM   #6
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
If you like the general tone of the exhaust and just want more volume, then this should work and be fairly cheap
Current: F80
Prior: F82, F32
      04-15-2021, 07:37 PM   #7
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
In addition to my reply above, it's probably helpful if I gave some context. My reference point will be S55 and F8X as that's what I have but it's likely very similar for S58 & G8X. On S55, deleting the secondary cats and resonators does make a pretty noticeable volume difference. One thing that you may not consider when you do this, though, is the way that the valves operate. For example, the valve isn't open ALL the time on sport & sport+; there are certain conditions that the valve will be closed (such as low revs in a high gear) in order to reduce drone. If you do a secondary cat / resonator delete, you may find that when driving even in sport/sport+ that it doesn't sound as loud until you hit higher RPMs - many don't realize this is due to the valves being closed. The solution is to either unplug the valves when open or use a valve controller to force them open all the time - there is a big downside though to the valves being open all the time (especially w/o the secondary cats & resonator) in that it drones like a MF if you're just cruising between 1.5-3k RPMs. The best solution is having a valve controller once they're released for the platform so you can have the valves open when you want the thunder and close them up when you're just trying to cruise.
Again this is all based on my experience with S55 & F8X, however, I do not imagine that the outcomes will be much different, if at all, with S58 & G8X
Current: F80
Prior: F82, F32
      04-16-2021, 01:15 PM   #8
weidake
weidake's Avatar
473
I'm Stopping by a exhaust shop today to see if they can just get it done for me.
      04-16-2021, 03:26 PM   #9
TrentMeister
2860
Drives: g82 comp
Damn you're beating me too it
      04-17-2021, 10:52 PM   #10
TigahRouge
TigahRouge's Avatar
No_Country
293
Drives: G05X5,G82C, Ram 1500
Yeah I saw that,
When you do let us know how it sounds.
      04-18-2021, 02:58 AM   #11
b3ngali
Brown Boy
b3ngali's Avatar
Drives: %E2%80%9822 M3 Comp xDrive
Keep us posted, man! Looking forward to hearing back from you.
2022 G80 ///M3 Competition xDrive (Speed Yellow)
Instagram: @m3llo_yello
      04-20-2021, 04:00 PM   #12
weidake
weidake's Avatar
473
There are 2 resonators before the muffler. Debating on which one to cut
      04-20-2021, 04:56 PM   #13
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
I know G8X has different exhaust routing than F97/8, but does it have a similar dual secondary cats into an H-pipe resonator like this?
View post on imgur.com
Current: F80
Prior: F82, F32
OwnerF16852.00
      04-20-2021, 11:30 PM   #14
weidake
weidake's Avatar
473
I took a screen shot of rk tunes video
      04-21-2021, 12:49 AM   #15
Thtkidwihthem3
Drives: 2010 BMW m3 e93 le man's blu
Stock catalytic converters!
Hey guys lmk what you guys end up doing ! I might need the stock catalytic converters 👍🏻 pm only thank you !
      04-21-2021, 10:02 AM   #16
tommydieselm3
Team M
tommydieselm3's Avatar
Drives: 2022 G80 ON ORDER
any updates on the sounds anyone delete anything yet? please keep us updated... this will be one of the first things I will want done when my car gets here... car is way to quiet!
thanks in advance
2022 G80 M3 Brooklyn Grey 6Speed=ON ORDER
2021 G80 M3 Tanzanite Blue=Sold
2015 f82 alpine white bmw M4=traded in
2010 e92 alpine white bmw m3=traded in
2003 e46 alpine white bmw m3=traded in/2003 e46 Laguna seca blue bmw m3=stolen
      04-21-2021, 04:06 PM   #17
weidake
weidake's Avatar
473
I'm starting with the 1st resonator and see how she sounds
RugbyBro7601.50
lch6257111.00
      04-21-2021, 05:01 PM   #18
weidake
weidake's Avatar
473
Wall-e saying hi
Appreciate 7
      04-21-2021, 05:14 PM   #19
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
Wall-e saying hi
Can you tell if those are H-pipe resonators by looking inside?
Current: F80
Prior: F82, F32
      04-21-2021, 05:29 PM   #20
weidake
weidake's Avatar
473
Wall-e saying hi
No h pipe both just go straight through
      04-21-2021, 05:38 PM   #21
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
Oh interesting, the second resonator must be an H pipe then. I'm interested to see how your car sounds with the first removed
Current: F80
Prior: F82, F32
      04-21-2021, 07:28 PM   #22
weidake
weidake's Avatar
473
Gut of the first resonator
RugbyBro7601.50
M3LISSA796.50
g80
