Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Has anyone experienced heat warp/fade with OEM brake pads?
Reply
      10-22-2018, 04:31 PM   #1
SnapCoupe
BMW Portland
Drives: Z4M Coupe/E90 335i
Yesterday I went for a spirited drive on a road with a lot of elevation changes. I was driving for about 30 minutes and on my way down I started to feel the brakes fading a bit. I wasn't being super aggressive on them as the road was pretty tight, but I decided to err on the side of caution and tone it down a bit for the last stretch. After 1-2 more corners, even mild-medium level braking felt really soft and unresponsive, and with the next application of the brakes I felt a strong vibration in the steering. This vibration was noticeable with any touch of the brakes up until I got home and parked the car. I was worried I warped a rotor, but the next day the car drove and felt 100% normal, so i'm thinking it was just pad deposits from the heat.
I replaced my front brakes with drilled Stoptech rotors and OEM BMW pads about 10k miles ago. The rears are OEM BMW rotors and pads with about 20k miles on them. I also have stock brake lines and did a brake fluid flush when I replaced the fronts.
So my question is, is this pretty typical for OEM pads on stock (excluding the front rotors) 335i brakes? I have driven my Z4M on the same route more aggressively and I have only ever gotten but a slight bit of fade near the end. I know the Z4M is a bit lighter and has M3 CSL derived brakes, but the speed at which the 335i brakes faded and started shaking is really surprising.
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S
      10-24-2018, 03:21 PM   #2
techwhiz
techwhiz's Avatar
Drives: e90 335i Sedan - Arctic
Pad deposits.
Rotors rarely warp.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
      10-24-2018, 04:11 PM   #3
SnapCoupe
BMW Portland
Originally Posted by techwhiz View Post
Pad deposits.
Rotors rarely warp.
While it is rare for rotors to warp, the reason for replacing my front rotors and pads recently was due to a warped OEM BMW rotor, which was a first for me.
Is there a technique for dealing with pad deposits when it gets to the point of shaking the car? Or is it just something where you have to let the car cool down?
      10-24-2018, 04:29 PM   #4
maddmatth
New Zealand
555
Drives: F82 M4, E92 335i
Don't stand on the brakes with the car stopped as that could make an impression or leave more deposits on the rotor if it's hot. If you need to stop try to smoothly release the brakes and then put it in park.
It's not hard to fade out street brake pads, even the sport type pads will fade if you're thrashing it on a windy road. You just need to learn to recognise it when it's happening so you can slow down and let them cool.
It varies depending on the pad but pedal feel/response will change as they approach this point and you might get a burning smell from the pads too.
Reply
