Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > Catalytic Converter Replacement
Reply
      10-01-2018, 01:01 PM   #1
hardlymick
Drives: '09 e91 328i
Just got the news today from my mechanic that the front catalytic converter (may) need to be swapped out.
Car is experiencing intermittent and very brief losses in power, and it sure feels like back pressure, but the mechanic has not been able to replicate the problem, nor get any diagnosis from the computer beyond the "Check Engine" light being on.
Mechanic recommends replacing both front and rear converters, which makes sense to do while the engine is out of the car. The problem is each California legal catalytic converter would cost me around $1250, meaning the whole repair is probably over $3500.
The car is probably only work $6k.
Asking the experts here is there are any other solutions to this problem that don't cost so much.
Thanks
      10-01-2018, 05:24 PM   #2
Brandon818
Brandon818's Avatar
Drives: 2012 335is, 2018 M5, 2003 M3,
2022 Mexico Blau M ...  [0.00]
2003 Bmw M3  [0.00]
2018 Bmw M5  [0.00]
2012 BMW 335is  [0.00]
buy used cats, or go catless
FBO 335is + Carbon Goodies
      10-01-2018, 07:51 PM   #3
hardlymick
Catless meaning you'll never pass another smog inspection?
      10-01-2018, 07:54 PM   #4
Brandon818
Brandon818's Avatar
2003 Bmw M3  [0.00]
2018 Bmw M5  [0.00]
catless as in paying 150-200 for a "special" smog
      10-01-2018, 11:01 PM   #5
e92_bryan
Drives: ‘11 e92 328
Lmaooo what rip off mechanic are you going to? Neither the n51/2 or n54/5 need to have the motors pulled to replace the cats, unless you’re doing other repairs hes 100% ripping you off
And you could buy the cats for cheaper from the dealership...
Even used is a good option
And CES light doesn’t mean anything until he tells you what specific code it is
      10-02-2018, 03:17 AM   #6
Rogue-OP
Rogue-OP's Avatar
59
Drives: to Drum & Bass
What model?
      10-03-2018, 10:28 PM   #7
Twin_Snails
Twin_Snails's Avatar
Drives: E92 335i
This ^. Whats funny is how the mechanic recommended replacing the catalytic converters yet can't replicate nor diagnosis the problem.
      10-27-2018, 10:43 AM   #8
Illoosive
Drives: E92 328i 6MT
Same thing with my e92. Turned out that there was oil on my spark plugs and coils from a leak. Also the OEM sensors 02 Bosch...were reading correctly but throwing a code. Got the oil leak fixed and used OE coil packs and OE o2 senors and Fixed leaking cover assembly and ecc cam sensor and check engine light went away after a drive cycle. Initially since everything was reading correctly everyone 3 seperate places mentioned it could be the cats. Maybe it isn't the cats.
      05-16-2019, 10:18 AM   #9
johnniewalker
johnniewalker's Avatar
Drives: 328 xdrive
Hi there, Can you explain what you are referring to by "cover assembly"?
I am having the same problem
thanks in advance
Performance Intake and Exhaust, Apex arc-8, KW v1, Vorshlag camber, ER brake lines, Lux V4, AA tune
Reply
