06-25-2018, 11:58 AM | #1 |
Rep 135
Little oil leak...looking for thoughts
I was poking around under the hood this weekend and came across a little bit of an oil seepage up near the valve cover and a little drip below towards the front of the engine. I attached a few pics and would like some opinions.
I started snapping images after I wiped some of the oil off on the area highlighted in the first pic. It was a thin layer of oily black gunk, nothing major but a coating across that area. You can still see a little bit of it towards the bottom of the pic. The second image is pre-wiping surfaces. Thanks for any thoughts.
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i |
06-28-2018, 03:21 PM | #3 |
Rep 135
I ended up emailing the pics to my mechanic. He thinks the top pic is the valve cover gasket and the bottom may be due to the oil relief valve. I'm overdue for vanos work and need to take the whip in anyway, so they'll be digging in next week. I'll update the thread with what they find.
07-02-2018, 04:53 AM | #4 |
Rep 97
Due to the location and smear pattern I guess it's a leaky vanos to head steel gasket.
Had it, fixed it! Good luck with the clean up!
perdidit in spatio
18" Arc-8 - Michelin Cup2 - KW V3 - GC camberplates - RE trans mounts - VT engine mounts - Vorshlag RTAB shims - RPi - stubby - CDV del |
07-04-2018, 01:49 AM | #5 |
Rep 878
First is probably valve cover and the second is probably chain tensioner gasket.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
04-02-2019, 09:51 AM | #7 | |
Rep 135
The valve cover gasket and oil relief valve were both replaced and the leak(s) haven't returned. The leak in the first image posted was likely valve cover gasket and second leak was likely oil relief valve. Hope this helps!
