M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > Taillights are a magnet for leaf gunk.
      04-09-2018, 11:34 AM   #1
McGary911
McGary911's Avatar
Drives: 2017 LBB M2 DCT
Every time I wash the car I dry around the trunk and notice a few little leaves and whatnot get in the crack at the top of the taillight. The way the car's designed this is pretty much inevitable. Today I popped off the tails and gave it a real cleaning. There WERE leaves in there I couldn't get to without removing the tails. These cars are new and not rusting yet, but I know that leaves and dirt are moisture magnets so I figure this is something I'll do every 6 months or so.
Easy to pop off. 2 nuts and a good pull and they pop right out. 2 wire plugs and they're completely off the car and you can throw them in the dishwasher for a good cleaning. Kidding on that part.
2004 E46 ///M3 SMG Convertible Carbon Blk\Imola
2017 LBB ///M2 DCT
2013 Porsche Boxster S
emargul204.50
///MPhatic13864.00
      04-10-2018, 05:56 AM   #2
emargul
emargul's Avatar
Drives: M3
Great idea! Where are the two nuts located?
      04-10-2018, 07:29 AM   #3
McGary911
McGary911's Avatar
Re are 2 little plastic doors one of which you can see in my first pic. Just pop those open and get in there with a 10mm socket on an extension.
You have to give the light a reasonable yank to pull it out. The front corner is held in by a pin and grommet type gig. Remember there are wires attached, so when it lets go, don’t end up on the other side of the garage. There’s actually a handhold on the inside edge of the light so you can get a better grip.
When you put them back on, a little bump with of heel of your palm will reseat the grommet and pin.
I knew how to remove them from when I changed my tail bulbs to LEDs. It’s easy. Good luck.
2017 LBB ///M2 DCT
emargul204.50
///MPhatic13864.00
      04-10-2018, 08:24 AM   #4
emargul
emargul's Avatar
Drives: M3
You have to give the light a reasonable yank to pull it out. The front corner is held in by a pin and grommet type gig. Remember there are wires attached, so when it lets go, don't end up on the other side of the garage. There's actually a handhold on the inside edge of the light so you can get a better grip.
I knew how to remove them from when I changed my tail bulbs to LEDs. It's easy. Good luck.
Thank you!! I'll definitely give it a shot the next time I wash my car.
      04-10-2018, 08:49 AM   #5
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
That is my 1 complaint w/the car's design. Well dash visibility but I got over that
      04-12-2018, 09:05 PM   #6
amancuso
amancuso's Avatar
726
Drives: 330it, 428ix, 430i
The leaf trapping tails are nothing new on BMWs. My e39s always trap leaves as well as my Z3 roadster. My oldest will be 20 yrs old this October, and it's not rusting behind the tails.
2016 428ix, r, 2018 430iC, 2018 330it
spencers199.00
      04-13-2018, 06:43 AM   #7
Bruce_SC
Drives: Truck
Its also a good idea to every so often to pull your front inner wheel well plastic and clean out those. We pulled some on an M3 and lots of junk came out from the cowl drainage and motor drainage.
Bruce
      09-14-2022, 09:54 PM   #8
billypopo
Drives: Bmw 435i GC, glacier silver
Resurrecting this thread; there's a massive tree right above my parking, so this spot is always full of leaves and other organic stuff. I don't feel like removing my tail lights every 2 months so I'm thinking to put a silicone bead at the upper junction between the lights and the body. Anyone did this?
      09-15-2022, 01:44 AM   #9
M Fifty
Drives: M2 & 330CI
As the gap between the light moulding and the body appears to be the drain for the channel around the trunk lid (which is why the leaves end up in there), might that not cause other problems?
      09-15-2022, 07:58 PM   #10
billypopo
Water will drain over the tail light instead of behind I believe. When I dump a fair amount of water above it's 50/50 between behind and over the tail light
      09-15-2022, 08:23 PM   #11
///MPhatic
The Seeker
///MPhatic's Avatar
13864
Drives: OG M2 • Exige
Man I hate this spot. This thread has inspired me to take the tails out and clean that area properly since it's no longer my daily. I have to do the same thing to my fender liners.
      11-26-2022, 07:31 AM   #12
hybrid90
hybrid90's Avatar
No_Country
246
Drives: 2021 X3 M40i
2021 BMW X3 M40i  [10.00]
I've been reading that the taillights develop a short because of a bad ground. Since the connecting plug is on the backside of the taillight, this plug is actually exposed to the water running down from the trunk drainage. I know this because I am dealing with this problem right now. Can't seal the top because then it will be stuck to the car so once I get it fixed (of course it had to happen on Thanksgiving weekend when my Indy shop is closed), I'm going to find a way to wrap and seal the plug. It's a really bad design IMO but what are you going to do?
m2
