01-09-2018, 08:24 PM | #1 |
Rep 16
O2 sensor simulator
Does anyone have a link for a place to buy oxygen sensor simulators? I have had down pipes for awhile now and the SES light is starting to bug me. Www.o2sims.com or whatever it was seems to have vanished from the internet and they are the only ones people seem to have mentioned.
01-09-2018, 10:04 PM | #2 | |
Rep 12,565
3GFX722.50 |
03-07-2018, 09:12 AM | #3 |
Rep 912
03-07-2018, 09:17 AM | #4 |
Rep 11,668
This.
03-07-2018, 09:35 AM | #5 |
Rep 912
Beautiful. Just to clarify....with no cats...I would need 2 of these sims one for each pipe correct?
I've reached out to the tuner to see what can be done as well. Wanna double check to see exactly how they programmed the car. If the second cat is "turned off" I will have no choice but to go get it tuned anyway before it will even read the simulator. |
03-07-2018, 11:34 AM | #7 |
Rep 2,705
Send Area 74 a note on their website
03-07-2018, 01:00 PM | #8 | |
Rep 12,565
03-07-2018, 01:03 PM | #9 |
Rep 12,565
Yes but for N55 you’ll only need 1. And install should be little easier because N55 is more accessible. If your m54 is anything like mine where the post cat o2 sensor connects underneath the car, you will most likely install on the DME side inside the ECU enclosure. And honestly I prefer that anyway because the sensor is protected from the heat and weather (and remains hidden). Removing the ecu took more time than installing the sensor.
Pictures are down but my brief write up: http://www.zpost.com/forums/showthread.php?t=1394920 Last edited by 3002 tii; 03-07-2018 at 03:35 PM.. |
3GFX722.50 |
03-12-2018, 05:53 PM | #10 |
Rep 16
Hi all, i ended up buying two simulators from magnum tuning and they work great. They were still pretty expensive but they worked. They were simple to install. I bought the ones that dont have the heater circuit in them as they were way too expensive but i wish that i bit the bullet and bought them for completeness of the mod. I am going to make a small metal box and house the heaters to avoid excessive heat under the hood or perhaps find a suitable resistor (something heavy duty like ceramic) to bypass the heaters.
No codes so they 100% work
2003 BMW Z4 e85
Bilstein B12 Struts and Springs|S52 Downpipe w/ Custom Adapter Plate|Style M208 Wheels|Oil Catch Can|Strut Tower Brace|Intake Scoop|CAI|AUX and Bluetooth Fitted 1987 BMW 535i e28 Stock Restoration Project Last edited by JCampbell_Soup; 03-12-2018 at 05:58 PM.. |
3GFX722.50 |
Tags |
bmw z4, catless downpipe, oxygen sensor, simulator |
