      12-19-2018, 08:15 PM   #133
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
Hell yeah man can't wait to see you figure this out!
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
      12-20-2018, 04:10 PM   #134
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
Presented without comment:
      12-20-2018, 06:58 PM   #135
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
OMG
The time and brain matter to do this....this is amazing.
Racerbruce
      12-21-2018, 02:39 PM   #136
mattfwalters
AEM just confirmed that my solution is almost identical to what they have baked into the PnP harness. So this is going to work.
      12-26-2018, 10:18 PM   #137
mattfwalters
Didn't really do anything useful today, but did rough in the routing for 4 of 6 gauge sensors (fuel pressure, oil pressure / temp, water temp; the other two with sensors are wideband O2 and will be much easier to deal with wiring), changed the harness to use the intake air temp sensor with the Evolve airbox, removed some connectors and wires from the engine harness that I won't be using, and cleaned up / re-loomed a bunch of other wires that have been straggling around and bothering me:
Vanne1620.50
longress104.50
      01-02-2019, 08:36 PM   #138
mattfwalters
No photos, but the interior is stripped to the forward carpet and the dash is now free. Having a bit of a time trying to get the steering column / controls / wheel removed so the dash can come out but I'll get there tomorrow. I mocked up one of the two dash panels using very thin aluminum and I was pretty happy with it, so as soon as I can get the dash pulled and the rest of the wiring I don't need pulled out I will start the process of integrating the Infinity harness with the E86 harness and creating new bits of harness where required.
On a related note, although I did manage to scar the vinyl on the back edge of the drivers' side door card a bit (I would suggest transplanting the Sepang leather to your existing door card, it's on a separate metal panel so should be doable), I now have complete Sepang Bronze over black carbon-weave leather interior available. I'd like to sell the seats and door cards together, and same deal if somebody wants the three carbon-weave leather inserts. If anybody needs plastic interior trim pieces or is interested in the seats, trim, or steering wheel, hit me up.
      01-03-2019, 08:29 PM   #139
mattfwalters
I had a funny feeling that I was missing something obvious about the steering wheel removal - and I was. I had noted the airbag / center unit release holes on the wheel before but hadn't pressed the spring hard enough. A couple of hours today got me to here:
And an hour of work got the gauge / control panel to here:
(This is not painted, this is bronzed aluminum)
I've fished (almost) all of the wires I care about through the firewall and am about to head back out and start wiring up the main power distribution / relay / fuse stuff, after which I will get the ECU mounted (in the cabin) and start wiring it up and testing things.
Lots more unused wiring to come out, but this part of the project is really starting to come together.
Here's some photos of the piles of stuff I've ripped out of the car. PM offers if you see anything here you need / want, or PM requests if there are things you don't see here that you need / want. Good chance I'm getting rid of it.
longress104.50
      01-03-2019, 09:09 PM   #140
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Welcome to the dark side...
      01-03-2019, 11:25 PM   #141
mattfwalters
It's cozy over here! And way easier to work on stuff.
Wiring and mounting of electronical stuff has begun!
      01-04-2019, 04:52 PM   #142
Steeler
Steeler's Avatar
2429
Throw an ad in the for sale forum for all those interior bits. You will get a lot more traffic.
      01-04-2019, 10:10 PM   #143
mattfwalters
Really getting into it today. Main fuse panel, fuel pump / fan relays, main 60A fuse, ignition / fuel / fan switches all wired and functional:
..and the ECU lives!!
So tomorrow I'll build the tach / indicator panel, prep relays for the starter solenoid and oil accumulator solenoid, and then move this mess into the car and start merging the harnesses. Exciting!
longress104.50
Vanne1620.50
      01-04-2019, 10:11 PM   #144
mattfwalters
I will do once I feel like sorting through and photographing everything. Until then, folks following the build thread can probably get a really good deal on stuff since I'm lazy.
      01-05-2019, 09:43 AM   #145
racerbruce
racerbruce's Avatar
3854
GO Matt F....ing Walters!
This looks slightly more technical than when i replaced my rear turn signal bulbs with LED lamps....you're freaking amazing.
Racerbruce
      01-05-2019, 01:08 PM   #146
Michael9218
595
Ok, so I'm curious why you didn't go with an AEM CD-7 dash data logger in place of 7 gauges?
      01-05-2019, 04:20 PM   #147
mattfwalters
I like gauges. I don’t like LCD multifunction displays. The Infinity is also a logger. I wanted to take a crack at building out the whole dash / electrical system myself. So.. personal / aesthetic preference and indulging myself.
Vanne1620.50
      01-05-2019, 09:52 PM   #148
mattfwalters
Today I set up the dash panel for behind the steering wheel: tach and indicator lights. Wired up indicators for main ignition and the oil accumulator solenoid (damn thing draws a full amp when it's energized, ugh); set up relays and switches for the accumulator solenoid and starter switch. Moved the works back into the car:
And then I got irritated with the stock chassis wiring harness and started ripping it apart.
My goals for tomorrow are:
1. Finish ripping out the stock chassis loom
2. Wire up fuel pump power
3. Drain fuel tank with the fuel pump like I should have done before starting the project
4. Wire up starter / solenoid
5. Wire up crank / cam position sensors
6. Wire up gauges and sensors
7. Finish the oil system plumbing
8. Put oil in the car
9. Spin the engine with the starter and verify that the Infinity tracks the crank / cam position sensors!
Then there's still a big list of stuff to do but it's in relatively small increments. So close to running I can almost taste it.
      01-06-2019, 11:02 PM   #149
mattfwalters
Stock loom is cleaned up:
Gauges are all wired up and are alive:
ECU is driving the fuel pump, which I used to empty the fuel tank without getting any of that nasty old gas in the new fuel rail / injectors.
That's where I got to today.
Azeka1285.50
Vanne1620.50
      01-07-2019, 11:56 AM   #150
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Great progress. Just curious, are you building your car for any particular class?
      01-07-2019, 04:48 PM   #151
mattfwalters
Thanks!
Not really building for any specific class, but planning to do against-the-clock type racing rather than wheel-to-wheel. At least for now.
      01-07-2019, 04:49 PM   #152
mattfwalters
Originally Posted by WeekendWarriorz View Post
"....clearly emit an offensive, harsh, excessive noise or"
WELCOME TO 2019, where exhausts can be harsh and offensive to the new generation of millennial snowflakes... oops sorry I mean our beloved kids that we're raising!
Although I'm guessing this was meant for a different thread, I'm pretty sure my car will make offensive, harsh, excessive noises. So thanks for the heads-up!
      01-07-2019, 06:37 PM   #153
EMagnuson
Drives: 2007 Z4M Coupe
They are going to use "Sound" judgement for excessive noise. Do you think the person writing that did it on purpose?
      01-07-2019, 08:27 PM   #154
WeekendWarriorz
670
Drives: 2006 Z4M
Hahaha no, I meant to post this in the thread for the new California exhaust laws passed for 2019. I use the mobile app so it gets a bit buggy, my mistake back to topic of this awesome build
