04-24-2017, 10:26 AM | #1 |
Rep 326
Opinions On Good Drying & Detailing Towels
Can anyone recommend drying and detailing micro fibre towels that are edgeless? Also, I've heard that we have to wash the towels in a specific soap to keep it's softness?
Amazon Canada friendly would be great. |
04-24-2017, 11:56 AM | #2 |
Rep 236
Drives: 2017 M2 6MT
I use edgeless MF from The Rag Company for QD and drying; Eagle Edgeless 480 GSM. This company has plenty of options depending on use and your methods.
I ceramic coated my car so it's just about washing, drying and QD spray for me. |
04-24-2017, 12:21 PM | #3 |
Rep 350
I've gone with a few different towels.
For drying I started with Meguiars waffle weaves, these are available from most places that sell Megs, including Walmart, Canadian Tire, Amazon, etc. Dry pretty well, not bad size wise. Then I got a Chemical Guys waffle-weave, it's massive with pockets from Amazon, it perhaps absorbs a bit more than the Meguiars towels, the size is nice. I've recent picked up one of The Rag Company's Puffle Drying towel 20x40", it's smaller than the CG towel but still plenty big enough for F22/F87, it absorbs really well but is a bit linty still after a couple runs through the wash. Once it stops leaving fluff behind it should be really nice (from eShine here in Canada), it isn't edgeless, it has satin edges. For waterless washes and general buffing I started with eShine's El Cheapo and Cookie Monster towels. The Cookie Monster towels are very nice, great for buffing. The El Cheapo are fine but nothing too special. I then got some Chemical Guys towels from Amazon, they're somewhere between El Cheapo and Cookie Monster but with a nicer satin edging. Recently I also picked up some of the Eagle Edgeless towels from eShine, I haven't used them in earnest yet but they seem very nice and probably an upgrade over the Cookie Monsters. For purchasing in Canada I recommend eShine, Old Town Auto Spa, they're both based in Ontario, there is also Auto Obsessed in Edmonton that have an online store, that can work nicely. Otherwise it's mostly Amazon for me. I haven't tried buying from Chemical Guys directly in Canada, I've used Amazon for their stuff usually (but price watching is important on their stuff, prices can vary a lot). |
hshot_rooke122.50 |
04-24-2017, 10:34 PM | #4 |
Rep 120
My Milwaukee cordless leaf blower is excellent at removing a majority of the water in my car after a wash
After that I use whatever microfiber towels I have around. Like the ones from Costco. I have a few newer nicer ones that I got as gifts but the Costco ones aren't bad. |
recycledAlva291.00 |
04-25-2017, 06:23 AM | #5 |
Rep 257
It usually depends on the vehicle. Ones that are coated or have a really good wax or sealant can use the hose flooding method to remove a large portion.
After that, it a large edgeless microfiber towel. There are many companies that make them. I use MicrofiberTech, big white whale. Bruce |
04-25-2017, 07:13 AM | #6 | |
Rep 326
Will check out your recommendations. |
04-25-2017, 07:22 AM | #7 | |
Rep 326
04-25-2017, 08:58 AM | #8 |
Rep 236
Drives: 2017 M2 6MT
I did the research, talked with some reputable detailers that offered ceramic coating, got some quotes and chose the detailer and product that met my budget and I felt good about. If I was more prepared... I would have coated right away as there is no reason to wait. The longer you wait, the more paint correction you'll need.
04-25-2017, 12:41 PM | #9 | |
Rep 326
04-25-2017, 01:28 PM | #10 |
Rep 228
Glass Pro coated mine, all I use is water and Costco microfibre cloth. I do throw them out after a few wash if they picked up any debris.
05-04-2017, 09:53 AM | #11 |
Rep 642
First wash for me yesterday and I found this drying towel to be excellent. It is 28" X 20" in size which is a bit smaller than the one available direct from Griot's. One pass was all it took to dry a section sweep. I am going to get a couple of the smaller ones for the front bumper and those types of areas and keep the larger one for the bigger surface areas. Care instructions are listed on the package and are simple enough. Nice quality product.
https://shop.advanceautoparts.com/p/...919%7CL2*14989 https://www.griotsgarage.com/product...fType=&from=fn |
05-04-2017, 11:17 AM | #12 |
Rep 120
I just received this kit and know Matt did his diligence putting it together. I've only used the blue drying towel with Ammo Hydrate paint moisturizer so far. All great stuff!
https://obsessed-garage.myshopify.co...fiber-solution |
hshot_rooke122.50 |
05-04-2017, 01:07 PM | #13 |
Rep 16
CR spotless Di-ionized water system. Less u touch the paint the better. I love this thing. Rinse and walk away.
hshot_rooke122.50 |
05-06-2017, 09:48 AM | #14 |
Rep 20
05-06-2017, 10:59 PM | #15 |
Rep 16
The DI water system removes the minerals that cause the water spots. After the final rinse you can leave water right on car. When normal water is left on car and it evaporates, minerals are left on car causing the spots.
05-07-2017, 08:30 PM | #16 |
BimmerPost Supporting Vendor
1998
Rep 6,916
for drying nothing beats the metro air force blaster 8 hp
add either of these drying towels and you will have a solid set up. Adam's Great White Drying MF Towel Uber Super Drying MF Towel Also a good quick detail spray will assist you in the drying process Kenotek Showroom Shine Adam's Detail Spray |
05-08-2017, 12:57 AM | #17 | |
Rep 2,200
E9X Picture Game: 8 points: (High visibility jacket; Strip Club; Pizzeria; Sobriety Test; E9x dressed for Halloween, Billiards, Oil Change, Orange Cone)
05-09-2017, 10:00 AM | #18 |
Rep 2,948
Aside from the towels, I recently picked up a small shop blower at Costco for $30 CDN and will never, ever go back to towels only. This thing puts out 250 km/h winds and is small and light, it was a life-changing revelation haha.
hshot_rooke122.50 |
05-09-2017, 12:16 PM | #19 | |
Rep 2,200
05-10-2017, 11:50 AM | #20 | |
Rep 326
I'd love to get a blower to dry...$30, wonder if Toronto has any... |
05-10-2017, 11:53 AM | #21 | |
Rep 2,948
EDIT: Here it is on Amazon.ca |
05-10-2017, 12:38 PM | #22 | |
Rep 326
