M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > Wolfgang Paint Enhancer and Deep Gloss Paint Sealant
      04-16-2017, 05:21 PM   #1
jdarwin
jdarwin's Avatar
602
Drives: 2018 M4 Convertible BSM DCT
Before you spend large sums coating, try this process first. Just finished my BSM. Compared to a friend's Opticoat, neither of us can tell the difference. If your car is not a DD, I would recommend trying before coating.
2018 M4 convertible SBM
1990 E30 Convertible
2003 E39
      04-28-2017, 06:54 PM   #2
Mr 2
Drives: 2017 LBB M2
Been on the fence about getting a ceramic sealant or using something like Wolfgang Paint Enhancer. I plan to DD my M thought. THoughts?
      04-30-2017, 10:27 AM   #3
SuckaGDog
Drives: M5, C63 AMG Black Series
I've been using the Wolfgang Deep Gloss Paint Sealant and topping it with Wolfgang Fuzion Wax for the past 8~ years or so. Awesome combo.
I recently applied Dr Beasley's Nano Resin to my vehicle and it turned out great as well. I will most likely be moving forward with the Nano Resin application for future use. It is a great option because it is a coating you can do yourself, lasts 2-3 years depending on your environment. Con is the process of applying and the time frame to cure after, but it's worth it.
      04-30-2017, 11:17 PM   #4
Mr 2
Drives: 2017 LBB M2
Good to hear, I ended up buying some Dr. Beasley and will be trying that.
      05-01-2017, 06:38 AM   #5
Bruce_SC
Drives: Truck
Coating
This is an alternate method of protection, but not a coating. So visually, you may be correct that you cannot see any difference with the Opticoat, but the OPC is a true coating, and would not have to be reapplied later.
m2
