M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Higher Front Left Tire Temp?
      08-01-2016, 01:47 PM   #1
Acexxon
Drives: 2016 F06 M6 F87 M2
Hi guys, just wondering if any of you are experiencing a higher front left tire temp as well? Is this normal since I am driving on the left side?
The rear right tire needs to get checked out tm... it keeps slowly loosing air.......
      08-02-2016, 04:03 PM   #2
Poboy
Drives: 2016 M235i
If it is the same setup as the M235i then it is normal, the auxiliary coolant radiator is in the front left grill opening and is always open/cycling.
DrKevM52274.50
      08-03-2016, 02:15 PM   #3
NachoM
Drives: M2 Alpine White
Same here. Will ask why is this happening to the dealer although earlier reply might give us an explanation.
      08-08-2016, 06:02 PM   #4
Acexxon
This makes sense! Thanks!
m2
