Thread Tools |
| 10-13-2025, 12:26 AM | #463 | |
Rep 778
Drives: 2018 M2 6MT
https://f87.bimmerpost.com/forums/fo...play.php?f=657 For me, I have to scroll into the 2nd or 3rd page (the iOS app shows Page 2/n or 3/n in the lower right corner) when it crashes. This is on iOS 18.7.1 on both my iPhone 13 mini and iPad Air 4 with BIMMERPOST 6.9.6. Last edited by jefe2000; 10-13-2025 at 12:28 AM.. |
| 10-13-2025, 01:16 AM | #464 | |
all I do is test!!4
4964
Rep 998
Drives: I lost count of how many2
jefe20001265.00 ///M Power-Belgium86513.50 |
| 12-10-2025, 07:34 PM | #465 |
Rep 7,193
Drives: 2025 Fr. Preciosa Red G82 xDrive
Seems like there’s been a bunch of issues via the app lately. Photos don’t show up half the time, and I just got a message that I can’t send PMs because my account doesn’t have rights to (member for 19 years).
Version 6.9.6 Last edited by 'Cane; 12-10-2025 at 07:34 PM.. |
jefe20001265.00 |
| 12-13-2025, 10:34 PM | #466 |
Rep 7,193
New one:
I am getting flooded with email notifications from posts that happened days ago. Last edited by 'Cane; 12-13-2025 at 11:11 PM.. |
| 12-14-2025, 09:04 PM | #467 |
Rep 778
Drives: 2018 M2 6MT
apptest In addition to the items mentioned above by ‘Cane — which I’ve also seen — I’m noticing that embedded YouTube videos in posts no longer play correctly in the iOS app. For example, this post from Jason:
https://g45.bimmerpost.com/forums/sh....php?t=2219810 I’m seeing this in version 6.9.6 of the BIMMERPOST app on my iPhone 13 mini running iOS 26.2. |
'Cane12885.50 |
| 01-04-2026, 04:14 PM | #468 | |
Rep 778
Drives: 2018 M2 6MT
https://www.bimmerpost.com/forums/sh...php?p=32416177 |
| 01-05-2026, 12:07 PM | #469 |
Field Marshal
9015
Rep 2,368
The BIMMERPOST iOS App notification alert SOUND is not working for me. Please see the iOS and App version data in the photos below. I also seem to have no Search button either. Can't find it anywhere. iPhone notification sounds are "ON" for BIMMERPOST. The banner alerts work but there's never any sound alert. Surely this could be an easy fix??
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive/BE Bearings & ARP Bolts/LUX H8 180/DCT Tune by BPM Sport/PFC Z-Rated Pads/ECS Brass Brake Caliper Guides/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
| 01-09-2026, 09:48 AM | #470 |
Field Marshal
9015
Rep 2,368
^^ Anybody..... regarding the above??
| 01-09-2026, 10:31 AM | #471 |
all I do is test!!4
4964
Rep 998
DrFerry9015.00 ///M Power-Belgium86513.50 |
| 01-09-2026, 10:57 AM | #472 |
Field Marshal
9015
Rep 2,368
Thank you. Yes, I am getting alert sounds from other Apps.
apptest4964.00 ///M Power-Belgium86513.50 |
| 01-09-2026, 11:02 AM | #473 | |
all I do is test!!4
4964
Rep 998
| 01-09-2026, 11:06 AM | #474 |
all I do is test!!4
4964
Rep 998
| 01-09-2026, 11:19 AM | #475 |
all I do is test!!4
4964
Rep 998
| 01-09-2026, 11:19 AM | #476 |
Field Marshal
9015
Rep 2,368
YES - IT JUST WORKED!! Thank you!!!
| 01-09-2026, 11:20 AM | #477 |
Field Marshal
9015
Rep 2,368
WELL DONE 👍🏻
| 01-09-2026, 11:24 AM | #478 |
all I do is test!!4
4964
Rep 998
| 01-09-2026, 11:27 AM | #479 |
Field Marshal
9015
Rep 2,368
Yes I remember the BMW “Chime” sound. But what you fixed is still great. 2026 for me is “the year of fixing things that are not right” and this was one of those things albeit a tiny one. Water pressure regulators and leaking sprinklers are others.. I digress. Thank you again for your attention to this issue.
| 01-25-2026, 09:45 AM | #480 |
![]() 38
Rep 66
Anyone had an issue with "Schedule Service for tire wear" on their app?
During the brake module recall visit the service tech noted my rear tires needed to be replaced and this shows as “Tire service, rear tires” on my mobile app. I have replaced the rear tires but no matter how I change the tire settings on the IDrive the app will not remove the tire service needed notification. The new Continentals are all season tires, but not Star designated so the IDrive will not automatically read to reset my app. I even tried using the "manual tire setup" on IDrive. I researched using BMW AI Assistant and received a response "you cannot reset the worn tire" warning directly. I contacted my dealer and explained my issue and what I had tried on my IDrive and app. I asked if the service tech who recorded the tire wear finding could change my report to show new tires were installed to remove the "Vehicle Issue" on my app. The service specialist recommended all the things I had already tired. I explained again making the IDrive tire settings changes and verifying the air pressure was not removing the app "Vehicle Issue. I asked again if the service tech could change my report and it was suggested I make a service appointment. How to I remove the "Service Issue" for bald tires that have been replaced with new tires? Thanks |
| 01-25-2026, 09:50 AM | #481 | |
Rep 7,193
Wrong app. This thread is for the Bimmerpost app, not the MyBMW app. You can try signing out, deleting, reinstalling, then signing back in. Otherwise, good luck. Last edited by 'Cane; 01-25-2026 at 09:51 AM.. |
| 01-25-2026, 12:21 PM | #482 |
///M DAD
157
Rep 181
All embedded YouTube videos fail to play and show:
Video player configuration error (Error 153) This happens in every thread. Videos play fine if opened directly in Safari or the YouTube app, but there is no way to open externally from the Bimmerpost app. Device: iPhone 13 Pro Max iOS: 26.2 Bimmerpost app: 6.9.6 The /feedback link on bimmerpost.com appears to be dead and the app has no feedback option. Screenshot attached. |
| 01-25-2026, 12:35 PM | #483 | |
Rep 11,150
Drives: eVeRyOnE mAD!
| 01-25-2026, 12:55 PM | #484 | |
Rep 7,246
| Bookmarks |
| Thread Tools | |
