10-02-2020, 12:30 AM | #1 |
Rep 342
catastrophic failure of Evolve CSL Airbox
About 12 months ago I had an Evolve CSL Airbox installed professionally. Recently and very suddenly the car began to exhibit very strange low RPM performance issues.
Suspecting a Vanos solenoid failure, I took the car to my mechanic and this is what he found: 20201001_145612 by Eamonn Glass, on Flickr 20201001_145814 by Eamonn Glass, on Flickr 20201001_145652 by Eamonn Glass, on Flickr 20201001_145713 by Eamonn Glass, on Flickr ACK! I am not sure if the engine suffered damage. One cylinder is showing significantly lower compression than others. More investigation needed to determine. Quite demoralizing this kind of failure, as this could be very costly to repair, and I don't see how I could be at fault here. I have sent Evolve Automotive an email. I am considering: - buying a used VAC Motorsports CSL Airbox OR - waiting for a new v2 Turner Motorsports airbox to come available OR - seeing what Evolve offers, if anything, for a replacement Does anyone have experience with the VAC Motorsports CSL Airbox? Cheers, Eamonn aka eggman Last edited by eggman51; 10-02-2020 at 12:41 AM.. |
10-02-2020, 12:34 AM | #2 |
Rep 1,923
Geez.
Sorry to see that man. That is terrible and scary!! Hope evolve treats you well
10-02-2020, 10:21 AM | #3 |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
Hooooooly crap, that's horrible... Hopefully they are willing to help you out, considering it looks like the box just self-destructed. They've been making these for a good number of years now, and I can't recall ever hearing of someone have any sort of issue like this. Bad luck, blah.
Evolve CF CSL Airbox /// SGT Headers /// DKF Resonated S1 /// RPI Mufflers /// Underdrive Pulleys /// Alpha-N Tune Mstache /// CF Side Extensions /// Skyer CF Rear Spoiler /// CF Engine Cover /// Strong-Strut Braces H&R Coilovers /// MRR GF7 Wheels /// PS4S /// Remote Start /// Rennline Pedals |
10-02-2020, 10:38 AM | #4 |
Rep 3,004
Oh eggman!
This is terrible. Hopeful the significantly lower compression in one cylinder is not related to the airbox catastrophic failure; if it is, this will be an incredibly expensive repair and am hopeful if the cylinder in question ingested CF, it did not score the cylinder wall. Hate to go there, but if CF was ingested, this may have damaged some or all of the remaining cylinders. Our hearts go out to you and we will watch for your updates. Regards Racerbruce
Racerbruce
kaybat125.50 filtercoffee106.00 |
10-02-2020, 10:41 AM | #5 |
Rep 2,665
I agree, hopefully no engine damage. The airbox would be the least of my concerns, it's a pretty simple replacement compared to worst case.
10-02-2020, 07:05 PM | #6 |
dances with roads
4732
Rep 4,096
That is indeed catastrophic! I think my first priority would be engine health. Another intake will not be worth much with only 5 good cylinders.
PLEASE keep us updated. I have one of these intakes (+ tune) on my bucket list for the car. |
10-02-2020, 07:07 PM | #7 |
Rep 1,130
Oh damn this sucks, sorry to hear. Evolve airbox, being one of the nicest and priciest air boxes in the market... makes me wonder if my Turner airbox will turn out the same
10-02-2020, 10:25 PM | #8 |
Rep 528
Drives: E86 Z4MC; E92 M3
Under what conditions did you first start seeing/feeling the performance issues?
I had a similar - but not nearly as bad - experience with my Streamline CSL airbox where the epoxy completely gave during high temperature track driving. Thankfully I was tipped off because the line to the brake booster gave first, causing a leak and subsequent cutting of power to the engine. It's a good thing I stopped when I did because the engine almost ingested one of the fittings. I documented that all in this thread: https://www.zpost.com/forums/showthread.php?t=1647439 Streamline has been really good to me and a new box is on its way to me with a fix (higher temp epoxy and fittings that are also screwed/clamped together as a redundancy). Interestingly enough, I have heard of the new Turner boxes exhibited the same thing with the epoxy failing and pieces coming apart. They've been in the midst of correcting and resending boxes to their early adopters. Strange to see it from Evolve though, who are one of the oldest and most tried boxes on the market. I do hope everything is sorted with your engine though, certainly a huge concern though. Keep us all posted.
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
10-03-2020, 11:27 AM | #9 |
Rep 1,027
As others have asked, I would also like to know under what conditions the airbox broke?
Current: G87 M2 / F21 M140 / 718 GT4 | E89 Z4 35is
Gone: E92 M3 | RS3 8V | E82 1M | AMG GT-S | X3M Comp | F80 M3 | Juke Nismo RS | E85 Z4 M Roadster | R58 Coupe JCW | F87 M2C| F87 M2 | F22 M240i | F82 M4 | E89 Z4 2.0i | F56 Cooper S | E92 330i | R56 One Last edited by Dav3; 10-19-2020 at 02:57 PM.. |
10-03-2020, 11:18 PM | #10 |
Down Under!!
1621
Rep 4,294
holy shit!!! *just saw this now*
wow, thats definitively worrying. Very interested to hear how Evolve handle this. How much loss did the leak test show? the box is neither here nor there, if the cylinder sleeve is rooted, youll be up for an oversize which means engine pull. Please do keep us in the loop mate, very very interested in how this develops. I am also curious as to the cause. Its possible that due to the heat that the epoxy has given way, but i havent heard of that before.. also worrying ios what is that rock of stuff in your hand? is that part of the /glue/ they used to cement the support beam in place cos that sure as shit isnt epoxy.. as a side note, as i am looking at your pics, that acyually looks like complete shit how they have ...cemented... the intake funnels into the box. my Karbionius one had them epoxied into the box. Looks very messy that cement that they have used.. My grey ebay box has them epoxied better than that. I also have to ask, how hot did it get? how many laps (minuted where you on it when you discovered this?) I run a lot of laps , never seen this before.. As a lesson to us all, please check your airbox.
Powered by |
11-20-2020, 12:06 PM | #13 | |
Rep 3,004
Oh no!
Oh no - no resolution as of yet. Really hoping this is resolved in your best interests
Racerbruce
11-22-2020, 02:17 AM | #14 |
Rep 876
Yikes! Sorry to hear. Hopefully it will be resolved.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
12-10-2020, 06:55 AM | #15 |
Rep 3,004
Greetings from Seattle -
Eggman - checking in and hoping this is closer to resolution....in your best interests, of course.
Racerbruce
02-07-2021, 11:22 AM | #18 |
Rep 5,328
ready for updates
02-07-2021, 05:47 PM | #19 |
Rep 342
Yeh hehe I am terribly slow with this
I plan to make a blog post about it, but as a quick summary, after about 3 months I got it all sorted =| |
06-21-2021, 04:18 PM | #20 |
Rep 528
Any update on how this was resolved? Just read of the same thing happening to an Evolve plenum for the S65, immediately thought of your situation.
06-21-2021, 04:52 PM | #21 | |
Rep 3,004
Wowie!
We're all waiting to hear the outcome; did it cause internal damage?
Racerbruce
06-27-2021, 01:35 PM | #22 |
Rep 159
I will also post a word of caution on Evolve/Eventuri. I purchased one of the S65 airboxes some time back, copied below is my initial email to their customer service. It took ~5 months to get returned and receive a refund.
I recently purchased an Eventuri plenum for the S65 through Vivid Racing. I am not able to get the plenum to fit properly. The rubber boots will not seat properly on the aluminum rings, and the plenum rings are visibly too wide for the engine. Inspection with calipers yielded the following averages: OEM plenum: Ring ID = 52.0mm Ring OD = 69.3mm Ring cylinder center to center = 98.0mm Ringer cylinder diagonal center to center = 270.3mm Eventuri plenum: Ring ID = 52.0mm Ring OD = 68.5mm Ring cylinder center to center = 98.0mm (range from 97.2 to 98.7) Ringer cylinder diagonal center to center = 274.0mm (range from 272.7 to 274.8) As you can see, the diagonal measurements are 3.7mm too large on average, which is over 3.0mm too wide. The tolerances are also quite large, almost as if there was no bond fixture used to bond the velocity stacks and rings to the plenum lower half. Please advise if this is the normal level of quality of your product, or if this is a defective unit. https://photos.app.goo.gl/eEyEtXeaREweTnd6A Last edited by wss4; 06-27-2021 at 01:51 PM.. |
0-60Motorsports792.00 |
