03-09-2020, 10:08 PM | #1 |
Why so serious?
141
Rep 743
Where does this end go?
Hello everyone!
My center console light (storage between the seats) never turns on. Door open or close. The micoswitch seems fine and so do the fuses. And, I've changed the bulb to a new tested one, with no luck. May I please know where the connector end of the microswitch (white plastic end) goes in the event it's not plugged in...? EDIT: I think I found a pic showing it. Can someone confirm it's the connector on the right (right green arrow)? If so, where does it go? Thank you in advance Last edited by SwissArmy; 03-09-2020 at 10:17 PM.. |
03-10-2020, 04:20 PM | #2 |
Rep 12,565
The plastic nub on the bottom of your door may have snapped off so it’s not making contact with the switch
03-11-2020, 09:46 AM | #3 | |
Why so serious?
141
Rep 743
My light is just not on at all. Fuse and bulb are fine and switch is fine too. I suspect i did not plug the end of the microswitch in when reinstalling my rear console. I want to make sure I know where it goes before I start taking it apart again |
