03-09-2020, 09:41 PM | #1 |
Rep 3
Top Motor Replaced - Doesn't work
I replaced my convertible top motor today. I ordered JUST the motor (https://www.amazon.com/gp/product/B0...5-cd78f07a84d8). Installed it and did trunk conversion. The top will unlatch, and I hear/see the motor making sounds and shaking as if it's working - but the top doesn't come down.
Any ideas guys? |
03-09-2020, 09:55 PM | #2 |
Rep 12,635
Garage List E86 Z4 M [10.00]
You forget to turn the knobs?
03-10-2020, 08:34 PM | #3 |
Rep 171
Hey
In the event that you opened the hydo system when changing out the motor, try this. Engage the red Emergency handle & manually bring the top up & down a few times. Since the pump is self-bleeding, this should, if there are any air pockets remove them. reset the red handle & try the down switch again If the above does nothing. Since you've moved the pump to the trunk, take a flashlight and place it behind the top plastic on the pump & sort of shake the pump. Can you see any hydo fluid inside? If yes, while in trunk near the pump with the flashlight have someone push top down & after the motor starts with the flashlight behind can you see a decrease/increase in the fluid??? (1) (1) Yea, I know, that plastic top gets really yellow with age & it's tuff to see thru. If you can see a lot of fluid in the plastic top and it's not moving at all when the motor is running then you may have made an error when you changed out the old motor. However, if you took off the hydo lines when swapping out motors you may have somehow crossed the connections at the pump. This sort of cross connection could result in the motor running but no movement. When you start checking the fluid level in the above steps and if you can't see any fluid in the system, top it off with hydo fluid using the screw in the middle of the plastic top. This will tell you if you've either cured your issue or if there a leak within the hydo system. I've never swapped out the motor on the pump sooo, I honestly can't help with that. |
06-02-2020, 06:14 AM | #4 | |
Rep 23
Motor only replacement
Thanks |
06-02-2020, 09:27 AM | #5 | |
Rep 171
You can do the change out by either pulling the roof or going thru the trunk. There's also another guy who posted on youtube that he reach the motor by folding up the back of the convertible top. It might actually work, but I've never did it that way. There is a very good D/I/Y on youtube on pulling the roof. However, here is a D/I/Y on going thru the trunk from a UK Z4 Forum on pulling the motor. There are a lot of pic's and step by step instructions. https://zroadster.org/threads/z4-roo...to-boot.19256/ I've never done a motor change on the pump so I can't help you with that. Lot's of luck |
06-02-2020, 10:07 PM | #6 |
Rep 452
Interesting... I got the Z in January and it was sitting in the garage until now. Over the last few months I put the top down and up a bunch of times just for fun. The battery was disconnected most of the winter cold months because it needed the blow by heater recall done so I suppose there was a risk of fire.
Occasionally I would reconnect the battery and start up the engine. So recently I've been working on the engine doing some maintenance and when I was done with it and went for a drive the top would unlatch but would not open. Thing is though, the previous owner specifically told me that he replaced the top motor so it was new. He showed me pictures of the old rusted out unit. As I was getting pretty upset that now I have to replace the motor again I played around with the red handle in the trunk a bit and then sat down in the car and pressed the open top button and held it, I could hear a faint click of a relay somewhere and an extremely faint sound of a liquid rushing somewhere behind the driver's seat (I do know the motor is right there). Thought ok, what happens if I hold it for a while... so I did and started hearing the fluid rushing sound more and more like there was air in the hydraulics also and then boom the roof started to open, motor activated and since then I have done it a bunch more times and its still working today. I thought that maybe when he replaced it he did not bleed the system properly and left air in the system and was already thinking of pulling the roof and motor out to bleed the hydraulics however just came across this post where you (JAS1169) mention that its self bleeding so glad I didn't start the process! Here's one little quirk I had noticed though, before when the roof closed it was more or less gentle on the approach to the windshield but now it kind of slams a bit before latching on. Not a huge deal I suppose but any tips for that? Don't mean to hijack the thread but since we are on the topic.... |
06-03-2020, 07:09 AM | #7 | |
Rep 23
Thanks for all and any responses. |
06-03-2020, 10:33 AM | #8 | |
Rep 23
OK, I just finished removing the top pump/motor assembly thru the trunk, that link that you shared was very, very good and it made me decide to not remove the top. It is not a easy job, but if you follow the instructions, it's all there. (The motor case was half full of water). I tested the motor again at the motor to make sure that was the problem and sure enough. I did separate the motor from the pump and was quite surprised as to why more people aren't replacing just the motor. You have to separate very carefully and not loose any of the pins or spring, and have something to catch the fluid, but that's it! Watch how it comes apart and it really isn't a big deal. I ordered the motor $117, and fluid $16, from ebay. Note that you want to get the exact motor replacement. I found a seller that advertises the motor built in Germany, not China, so I will wait a week now and proceed to put it all back together when I get it. Thanks again for your posting and the link you shared. update to come* |
06-03-2020, 10:54 AM | #9 |
Rep 429
Belcom..... my top also comes down a little hard as well. I believe if you replace the tension straps (right word?) that will solve the problem.
Or simply reach up and "gentle it's approach"... as I do. That costs nothing and prevents a hard "landing" of the top to the windshield framing.
Sent from my smart phone...
06-05-2020, 01:30 PM | #10 | |
Rep 23
Just installed the motor only and thought I would share some pictures on this. I'm still waiting on the fluid to arrive so the top isn't functionable yet but I did test the motor hooked up and it seems to be right. I have say that the motor drive assembly is quite simple and bulletproof against putting it together wrong, it only can go together one way. I'll update the roof operation after the fluid arrives Monday. Note: the pin and spring connects the motor to the pump and drives the pump, make sure the spring doesn't push past the collar on the pin or it will collapse and not drive the pump. While holding the pin in hand, push the spring upward against the pin collar and if it passes over there collar you have to bend the spring END slightly so that it fits tight and doesn't pass over there collar. Last edited by BobR07Z; 06-18-2020 at 05:00 PM.. |
06-18-2020, 04:45 PM | #11 |
Rep 23
Okay, after completing the motor install and everything working great, I decided to work on the motor that I pulled out to see what the problem was and how difficult it was to dismantle the motor.. The pictures below show the motor taken apart. The end of the motor that the electrical is connected comes apart and you have access to everything. I made the mistake of trying to spread the cylinder away from the holding plate, I think if you just pry the plate up and away from the base you won't destroy it as I did, I used a chisel to open the tabs and don't think that was necessary. Instead just pry upward and separate the plate away from the motor. It had a broken solder connection at one point and after soldering it, put it back together and the motor worked. I then tried to solder the end plate to the cylinder and ended up hurting the electronics so I discarded this motor. This is all so that you can make a decision or see how the motor is put together. There is hope to rebuild or fix your own.
belcom204.00 |
06-19-2020, 12:21 AM | #12 |
Rep 429
Nice pics and follow up post.
I too subscribe to the theory about fixing things .... it isn't broken until I break it.
06-23-2020, 09:33 PM | #13 |
Rep 21
Drives: 2006 Z4 3.0i 6spd manual
BobR07Z, thanx for posting the pictures, without them i wouldn't have been able to fix my top. I replaced the motor yesterday and it didn't work. In the 3rd pic the 3 pins fell out, one was jammed under the bearing and would not spin. I searched all over the net and could not find a diagram of the pump/motor assembly. The pics you posted allowed me to figure out what went wrong. Thank you!!
07-21-2020, 07:50 PM | #14 | |
Rep 23
I did do the pump relocation though. Enjoy!! |
11-09-2021, 09:07 AM | #15 |
Rep 35
BobR07Z , my motor looked a little worse than yours when I pulled it out of the roof drain cavity. I did a little research on cleaning electric motors. I pulled it apart and sanded the copper contacts, put it back together and it works.
You pretty much did everything I did, when I relocated the motor to the trunk I got pressure in the lines by moving the top manually a few times, but no movement with the motor. (I can hear it spinning.) At one point I manually closed the top halfway and could not move it up or down by hand the pressure was so great. I had to pull the red manual switch to release the pressure. Do you have any idea why the motor works, the lines get good pressure, but there is no movement? |
11-09-2021, 06:13 PM | #16 | |
Rep 171
In the attached video you can clearly here the motor running but, no movement. ( yes, the red handle by pass has also failed in the video). In the video the motor is running but the top isn't moving because of some kind of pump failure. You can hear your motor running but no top movement. Yea, your pump may have unseen water damage, simply failure due to age or because you made an error of some sort putting the pump/motor back together. Yea, I know it's very costly, but a new pump/motor combo should get your top moving again. |
11-10-2021, 01:20 AM | #17 | |
Rep 12,635
11-10-2021, 06:53 PM | #18 |
Rep 171
Yea, I selected this video so mothly 5000 could see water damage to the pump/motor may not always simply be limited to the electrical motor. In that, from the pic's in the video the motor was rusting out. Yet, rust & all you could hear it running in the video and it clearly sounded like a normal running top motor....with one problem; the top wasn't moving.
Yes, I agree with you, when I saw him strapping the motor back into the convertible frame I wondered why he wasn't relocating it to the trunk. I also wondered about reusing the crush washers. In that, if a stupid washer went bad on a relocated motor in the trunk it wouldn't be the end of the world. However, if the motor was returned to it's original location and a washer went bad....pulling the top all over again. |
01-11-2022, 09:56 PM | #20 | |
Rep 35
There is a brass release nipple (for lack of a better word because that's what it looks like) that gets pressed whenever you pull the red knob. I'm pretty sure the spring behind the nipple was corroded forcing the nipple to constantly stay in the "pulled position". Luckily, I'm the moderator of a Facebook Z4 group and had a member meet me an hour up the road with a mint condition pump/motor combo out of his Z4M. I switched pumps/motors and the top opened immediately on the first try! It doesn't close on its own after about 6-7 tries. It does try and I have to pull on it a little to get it to close on its own. I'm guessing there is still air in the closing lines, perhaps? And that it will take several more tries to work 100%. If anyone has any ideas for that I would really appreciate it. |
03-24-2022, 07:15 PM | #21 | |
Rep 3
Pin and spring
