      07-15-2018, 12:55 PM   #1
Zapata
Zapata's Avatar
Drives: 2006 Z4 3.0i
Floor jack size?
Hello Team:
Is a 1.5 ton floor jack enough for the weight of the Z4?
Thank you very much.
2006 Z4 3.0i (Premium + Sports package)
      07-16-2018, 07:05 AM   #2
ZAR4MC
South Africa
93
Drives: '07 Z4 M Coupe
I have a 2 ton and a 3 ton trolley jack and i only use the 2 ton to lift the side of car enough for me to slide in the 3 ton on the central jacking points. In my opinion, the 2 ton doesn't lift the car high enough.
07 Z4 ///M Coupe - Sapphire Black / Imola Red
My S54 Journal
      07-18-2018, 07:19 PM   #3
bgeorge0049
Drives: 2006 BMW Z4 3.0si
I have a 2.5 ton low-profile floor jack that works well. I only use it to lift the car and then it gets supported by jack stands.
      07-19-2018, 08:55 AM   #4
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
I think from a capacity standpoint it would be fine. However, many of the jacks I've seen in that range have a rather high profile and could present problems on such a low car as ours.
      07-19-2018, 03:04 PM   #5
Reborn_
Drives: 2007 BMW Z4MC
Well, the car weights more than 1.5 tons. But you won't be lifting the entire weight at once, so it should be ok. Too close for my taste, though - I would use a minimum rated 2 ton jack, personally.
      07-19-2018, 03:32 PM   #6
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
1.5 ton is plenty capable for our cars. In most cases, you're only jacking 1 corner at a time, which is only about a quarter of the jack's rated limit. If it's a lower profile jack and you can get to the center point to lift the entire front or rear, that's still only about half it's rated limit.
      07-19-2018, 03:43 PM   #7
Reborn_
I completely agree. But it's not enough of a safety factor for my taste. Larger capacity jacks are relatively cheap - I wouldn't use a 1.5ton regularly. The other added benefit is the jack pad is typically larger, making things quicker/easier. I also typically rest my cars on 3 ton stands.
-The guy who used a scissor jack exclusively for like 3 years
XMetal1131.00
