03-24-2020, 12:53 PM | #1 |
1999 E46, 2002 E53, 2007 E85....all in progress
Rep 103
Oil level?
I just had my oil and filter changed a week ago and last night I hit the oil level button on my 2007 Z4
roadster with an N52 engine and this shows up. I drove it around this morning and got it good and warmed up and the same reading. I asked my mechanic about it and he said it seems it's a half a quart low. I added a half quart and it still reads the same. Before I got my oil changed it read up to the full line. Thoughts?
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... |
03-27-2020, 10:31 PM | #2 |
Rep 2,546
That's why I change my own oil, oh wait my Z4 3.2 has a dipstick though my X3 N55 does not. Either your shop did not fill it all the way or your sensor is a little off. I would be careful adding too much more since overfilling is bad too.
03-28-2020, 09:27 AM | #3 |
Rep 3
Hatesns
I also have a 2007 z4 and I change my own oil. Your machanic probably own put in 5 quarts of oil. It needs 7qts. I would add one half gt at a time and recheck you level. Do not overfill.
CrazyOneToo9.50 |
03-28-2020, 09:54 AM | #4 | |
Rep 103
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... Last edited by CrazyOneToo; 03-28-2020 at 07:17 PM.. |
03-28-2020, 11:47 AM | #5 |
your average JAMF
3101
Rep 4,094
Sounds like oil level sensor is probably bad. Shame on BMW for taking the dipstick from some motors (I assume they're all gone nowadays?).
'21 M2 Comp
'19 Golf R |
CrazyOneToo9.50 |
03-28-2020, 02:03 PM | #6 | |
Rep 2,866
This is the main reason why I don't like cars without a dipstick and the main reason why I went away from BMW when we were searching for my wife's DD. Well...that and a spare tire were the main reasons. |
CrazyOneToo9.50 |
03-28-2020, 07:19 PM | #7 |
Rep 103
I'm guessing they all have a missing dipstick now. That would make a stealership visit more likely.
03-28-2020, 07:33 PM | #8 | |
Rep 103
03-28-2020, 08:52 PM | #9 | |
Rep 103
03-29-2020, 03:35 PM | #10 |
your average JAMF
3101
Rep 4,094
^^ Sounds like the sensor is failing for sure based on it suddenly deciding that the oil level is fine. I'd get that rascal replaced.
'21 M2 Comp
'19 Golf R |
03-31-2020, 11:17 AM | #11 |
Rep 103
03-31-2020, 12:25 PM | #12 |
Rep 2,665
I think if it was reading partially full and then suddenly goes back to completely full with no other change that is most likely to be the sensor. I have no idea why this would happen right at an oil change. I would wait a week or two and see if anything changes or if relatively simple just replace the sensor.
As for BMW removing the dipstick because it isn't needed I see zero chance the dipstick doesn't read correctly but this system is far less reliable.
03-31-2020, 01:07 PM | #13 |
Rep 1,794
Drives: E86 3.0si
Sure would be nice to know exactly how many quarts the shop put in...6.5 plus your .5, you're right where you want to be. Unfortunately the sensor doesn't show overfills.
03-31-2020, 01:26 PM | #14 | |
Rep 103
03-31-2020, 01:29 PM | #15 | |
Rep 103
I will have to look in the manual again but I think mine does show if its overfilled.
04-05-2020, 10:54 AM | #16 |
Rep 18,733
I wish I had seen this post at the end of March. I could have helped out. I posted in the E90 Forum in detail how the oil level sensor and oil monitor system work.
https://www.e90post.com/forums/showthread.php?t=1533444 But in short, you are using the oil level indicator incorrectly. It's not your fault. It is BMW's because they've never sufficiently explained how the system works, they expect an owner to take his car into the dealership. The oil level sensor does two things, it measures the oil quality and the oil level. It measures the oil quality to help determine when to change the oil. It measures the oil level to have a data point for the ECU to protect the engine and operate the VANOS system. The VANOS system adjusts the intake and exhaust timing to maximize horsepower dependent upon engine load. The adjustments are made using oil pressure and flow rate. If the engine is low on oil, the ECU needs to know to control the VANOS system. That is the main purpose of the oil level sensor system. The secondary use is to allow the vehicle operator to check the oil level under dynamic operating conditions (i.e. while the engine is running) using the e-dipstick. What most likely happened is the tech who performed the oil change did not refill the engine block correctly with oil. He probably used the technique he was taught for an engine with a mechanical dipstick, which is to add a quart less than capacity, then top off after the engine is warmed up (to get oil into the oil filter). This works fine for a direct reading mechanical dipstick engine, but does not work for the N52 with an electronic dipstick (e-dipstick). The e-dipstick requires time, temperature, and operating conditions to get a correct reading of the oil level. The correct procedure for changing oil in the N52 is (1) drain the oil) and remove the residual oil in the oil filter housing, (2) replace the filter, (3) refill the engine with 6.9 quarts of oil. No guess work. This presumes the oil change is being performed on a level car (i.e. not on ramps). Not repeat the entirety of my linked-to post, but the N52 engine needs at a minimum of 20 minutes of continuous driving to determine a new oil level. Worse, if oil is added and the car is then immediately driven, the e-dipstick will report the incorrect "old" oil level (i.e. before oil was added) once the engine gets warm enough to allow the system to report an oil level. So what happened with you is the e-dipstick was reporting a half-quart low (because the tech probably added on 6.5 quarts to the 7 quart engine oil sump), so you added an additional 1/2 quart to top off the engine but did not allow enough time to get a new oil level reading (i.e. 20 minutes of continuous driving). So you then added the 2nd 1/2-quart and again didn't wait the 20 minutes. Hope this explains what happened so you'll not repeat the event again. I also suggest you take your car to a BMW shop that is familiar with the N52. And finally, you need to change your way of thinking to understand all automotive engines are perfectly safe to operate with less than a full load of engine oil. Read any owners manual of any street car (i.e. not a race car) on the subject of engine oil level and it will tell you that to keep the engine oil level between the low and high marks on the dipstick. This means to only add oil when the level is at the low mark, which on most engines means the oil level is a quart low; this is no different for the N52 and its e-dipstick system. The reading you got ("OK") meant the engine had enough oil to operate safely and it was not necessary to add the additional 1/2-quart. The N52 should be topped off at 1-quart intervals once the system notifies the operator that the engine is 1-quart low on oil.
04-06-2020, 12:31 PM | #17 | |
Rep 103
So if they put the correct amount in and I added 1 extra quart total is it safe to drive my car like that? It is reading full and OK now.
04-07-2020, 05:39 AM | #18 | |
Rep 18,733
I have a Z4 Coupe with the N52, per page 93 of the owners manual, the instrument cluster reports an over-filled condition by showing a block to the right of the e-dipstick graph in the gauge cluster. If the system is reporting ok, then I think it is safe to drive the vehicle. What I would do it take the car out on the highway for 30 minutes and take a reading while at speed and see what is reported.
04-08-2020, 11:40 AM | #19 | |
Rep 103
I will take it out ASAP, maybe this weekend. What year is your car? When I bought the car used it didn't come with an owners manual. It took me 3 tries (from BMW) to get what I am told is NOW the correct one. In the one I have now it shows the overfull message also. From what I understand the 2007 is a changeover year model. That's always great.
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... Last edited by CrazyOneToo; 04-08-2020 at 11:48 AM.. |
04-09-2020, 06:19 AM | #20 | |
Rep 18,733
04-09-2020, 11:54 AM | #21 | |
Rep 103
So the engines are mechanically basically the same in each car that has the N52 engine? I had assumed the Si version had a different engine since the horsepower is higher. Thanks for all your incredible info!!!
04-09-2020, 01:05 PM | #22 | |
Rep 18,733
