06-23-2015, 11:58 AM | #67 | |
Rep 11,135
Installing the drops is the most difficult and aggravating part of the install. Once the drops are in, the rest is just about mounting the cameras and setting them up to monitor correctly. A friend of mine just bought a house, and he's hiring someone to pull cable for eight cameras. He'll do the rest himself. Looking at the quote he receive, they charged him between $125 and $175 per drop. This obviously depends how difficult the drop is. |
06-23-2015, 08:46 PM | #70 | |
Rep 11,135
06-24-2015, 12:37 AM | #71 |
Rep 2,368
Do you guys do a clean install with wires inside the wall or wires running outside? Still looking for a contractor/electrician who is willing to do a clean install in the wall that is reasonable. All the contractors I have found want $3000-5000 to run a 4 camera PoE
06-24-2015, 08:11 AM | #73 |
Rep 11,135
06-30-2015, 04:09 PM | #74 | |
Rep 435
06-30-2015, 06:12 PM | #75 | |
DOPE
148
Rep 758
06-30-2015, 09:08 PM | #76 | |
Rep 3,241
The other cameras I have on the outside around the back of the house required that I had the runs pulled before I had an area in my basement finished. |
06-30-2015, 09:22 PM | #77 |
Rep 3,241
So I currently have a dilemma. I'm trying to figure out which camera to purchase to cover the front driveway area of my house. I've gone back and forth with some options but can't settle on a final choice.
Option one is to get the very good performing PTZ camera from Dahua, the SD59230S-HN. The pluses is the camera has very good zoom image quality with an optical zoom of 30x. Has very good night vision image quality. And the camera movements are very fast and responsive. The cons is the camera is big. I would have to mount it vertically under a soffit vent. The thing is going to stick out like a wart on my house. Also, the camera isn't compatible with my Hikvision NVR. So it'll necessitate another NVR solution. Option 2 is to go with a different Dahua camera, SD42212SN-HN. It's smaller than option 1 but still has the cons I listed above. Option 3 is to look into an ACTi B95. It's also very well reviewed as the Dahua 59230. It's the smallest of the PTZ cameras I'm considering. But it's pretty expensive and has the con of not being compatible with my NVR. Option 4 is to stick with the Hikvision outside cameras I've been using but get the native English firmware version 2332 model...functionally the same as the 3332s I already own. The con is no PTZ functionality. Decisions...decisions. |
06-30-2015, 09:24 PM | #78 |
Rep 11,135
Since my wife was out and about last night, I had a few hours to myself and decided to swap my cameras around. Much better now! Fully adjusted them, and although it was sometimes a bit of a pain, happy I did it.
06-30-2015, 09:25 PM | #79 | |
Rep 11,135
06-30-2015, 09:38 PM | #80 | |
Rep 3,241
I understand Hikvision is supposed to come out with a camera similar to the Dahua 42212. I'm also leaning towards an outdoor Hikvision camera with two way audio capability. More for the mic capability to record any audio but the ability to talk to whoever is at the front door could be something useful too. |
07-02-2015, 04:00 PM | #83 |
Rep 413
The market leader for professional grade IP cameras is Axis. The cameras can be pricey but the build quality, image quality, flexibility and feature set is unmatched. The Axis Camera Companion VMS is easy to use and works well for home installations.
"Most things I worry about never happen anyway"
-Tom Petty |
07-02-2015, 11:00 PM | #84 | |
Rep 11,135
07-02-2015, 11:02 PM | #85 | ||
Rep 413
-Tom Petty |
07-02-2015, 11:12 PM | #86 |
Rep 11,135
07-05-2015, 03:03 PM | #87 |
Rep 5,538
I ended up buying 1 Dlink DSC-5222L. I figured I won't be able to monitor the car 24/7 anyway and with this being motorized I can view parking lot and living room with just 1 camera
07-05-2015, 03:05 PM | #88 |
Rep 11,135
