      05-23-2019, 01:02 PM   #1
rsutoratosu
Drives: Z4 3.0i
Tapping reverse light power
Any issue to tap the reverse light power when in reverse for backup camera ?
thanks
-Roranji
      05-23-2019, 03:37 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Probably not, but to be safe on how much additional load you're adding, I would couple the mod with an LED replacement.
The power reduction from switching to LEDs will cover the power for the camera and you'll still come out ahead.
No bulb-out sensing on the reverse lights.
      05-23-2019, 04:17 PM   #3
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Which LED bulb did you go with or that you would recommend? Any anomalies using LEDs such as "glowing" when the car is off and/or flickering while reversing?
      05-23-2019, 04:29 PM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
I have some 30W CREEs off eBay.
Polarbert was just looking at some 50W CREEs in another thread.
XMetal1131.00
      05-25-2019, 12:29 PM   #5
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
thanks
I tapped the reverse light for my backup camera and it works fine. Although, different cameras may have different power requirements. Which are you going to install?
2008 Z4 3.0si Coupe
      06-24-2019, 08:34 PM   #6
04MurderedZ4
Drives: 2004 BMW Z4 2.5
Relay
I tapped my reverse light power for my backup camera but put a relay in box with the battery. Everything was close and easy. I have been using it for 2 years with no problem.
      11-05-2019, 02:35 PM   #7
rsutoratosu
Drives: Z4 3.0i
Thanks, sorry I stop working on this. any specific brand of relay to use ? I just have some cheap chinese camera I ordered.
-Roranji
      11-05-2019, 02:39 PM   #8
rsutoratosu
Drives: Z4 3.0i
https://www.ebay.com/itm/12V-DC-Car-...5.c10#viTabs_0 like this.. right.. seems easy enough..
-Roranji
