      07-30-2020, 10:21 PM   #1
Wuweiying87
Drives: 08 m3
z4 m ground control /koni / tck double adustable
Pull off from the z4 m coupe , I bought rhem was told they would fit E36s , but the front coilover shaft is bigger than the E36s , so I can't reuse my strut mount, it needs the z4 one to fit , koni double adjustable front shocks, has no leaks, good compressions , rear is tck double adjustable shocks, one shock has slightly leak from the top adjuster knob, both shock has good compression
These is shocks only, I don't have the front spring perch and springs and camver plates , also the rear spring and rear spring adjuster also, sold as it. 450
located in san francisco
sorry do not know how to post pictures here
text me 415-513-6491 for picture
or
facebook marketplace:
https://www.facebook.com/marketplace...8326720375963/
