07-09-2012, 09:34 PM | #1 |
Rep 94
How many coolant hoses to replace? Should I replace them?
Looking to do some preventive maintenance on the Zed. Model is a '05 3.0 M54 engine.
Will be replacing fluid, expansion tank, waterpump, thermostat & housing. I'm leaving the radiatior as it looks pretty good for 78k miles and I have a limited budget. Should I do the hoses? I hear there's an upper and a lower but on REALOEM, I see a total of 3 water hoses. How many and which ones should I replace? (The hoses feel fine. Firm, not dried out, etc. and no leaks anywhere) |
07-09-2012, 10:14 PM | #2 |
enthusiast
48
Rep 1,695
If they are fine, I would leave them alone. If you need to replace 1, I would replace all with silicon and you'll never have to worry about them EVER again.
07-10-2012, 06:56 AM | #3 |
Rep 2,138
Drives: Me
The hoses don't really go bad, it's the O-ring in each end of the hoses that starts leaking.
07-10-2012, 11:39 AM | #4 |
Rep 94
are they replaceable?
07-10-2012, 02:38 PM | #5 |
Rep 2,138
Drives: Me
Yes, the O-rings are replaceable, but NO they (BMW) do not sell them alone. You have to size them yourself. Remember, they are METRIC O-Rings.
The piece (O-ring) that normally fails first and starts leaking is the temp sensor. The first sign of a failing O-ring is you start to loose coolant but there is NO coolant on the under tray... What happens is an O-ring is starting to become non-elastic and HOT coolant is weeping past and flashing into steam... You can pull a hose off in about 2 minutes. They use positive locking wire spring retainers. Just pull the retainer up and pull the hose off. Cold of course. Also make sure you do a very good visual inspection to the tank. Tanks are a known failure item on the M54 motors. |
07-10-2012, 04:03 PM | #6 |
Rep 94
YOU are the MAN!!! Just saved me a bunch of time and money. Thanks for the tip!
I'm going to change the expansion tank with a new one as a precaution. I can pick up the O-rings from Home Depot or Autozone. Material of O-ring matter? |
07-15-2012, 03:15 PM | #7 | |
6 of Diamonds (ret)
82
Rep 566
Scroll down to Proplyene Glycol, although most materials are compatible with it. Also look at the application: Heat range, Vibration, Pressure, Vacuum etc http://www.marcorubber.com/material_chart.htm Someone else may have a line on sizes - If not and it was me, I would get a nice set of calipers and measure. http://www.amazon.com/dp/B001C0ZPNO/..._df_B001C0ZPNO You can find good quality cheaper than this. Measure what? O-rings are spec'ed for size by interior diameter and thickness(cross section). 1. ID: So if you can measure the diameter of the what the hose will attach to that will get you close. You still need to determine the cross section. 2. Cross Section: If there is a groove that the oring fits in within the hose and you can measure that - you may have your answer but it may need to be smaller here because its going to compress. 3. you should also measure the O-ring directly, to see how this corresponds to previous measurements . Cross section wise this is probably the better of the two Just cause I'm so anal then I'd probably buy that size and one size up and down. Glad I saw this - I replaced all hoses on my 3, but probably not with the z. Last edited by BruceJ; 07-15-2012 at 03:30 PM.. |
07-16-2012, 01:36 PM | #8 | |
Rep 94
wow! that's a wealth of information, even a bit overwhelming! lol
thanks, i'll definitely look into it! Quote:
