      08-08-2020, 10:48 AM   #1
UncleWede
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
a
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
Ok3094.00
      08-08-2020, 10:49 AM   #2
UncleWede
UncleWede's Avatar
or C
GenXer1363.00
      08-08-2020, 12:08 PM   #3
rwheels
Drives: E93 M3
Just my opinion, but I would go with "a". The second one looks photoshopped, if you will; rather busy.
Murf99314114.00
      08-08-2020, 12:32 PM   #4
overcoil
Drives: M235i 6spd
are both pieces the same smoothness ? I'd probably choose A also for furniture quality.
But B would make a really good looking box or something.
Are both pieces cut to size and sanded or are you going to add finish ?
      08-08-2020, 01:21 PM   #5
AnOldBiker
Jim
AnOldBiker's Avatar
Drives: 2019 X5 XDrive 40i
Most ply has an A and B side.
The A is best and is usually on the seen side.
      08-08-2020, 01:25 PM   #6
UncleWede
UncleWede's Avatar
It's already cut for the table and each side has a single coat of varnish at this point. These are BBQ tables that used to have particle board as a top
Here's the one I finished last week
overcoil3073.50
      08-08-2020, 02:41 PM   #7
RickFLM4
RickFLM4's Avatar
Drives: M4
I’d say c.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      08-08-2020, 04:26 PM   #8
GenXer
Drives: Like a bat out of hell.
I like the knot in the wood
      08-08-2020, 04:31 PM   #9
BimmerDimmer6
BimmerDimmer6's Avatar
Drives: 2016 F80 M3 6MT / 2019 Raptor
What kind of table? Like where is it going to be used?
      08-08-2020, 04:33 PM   #10
UncleWede
UncleWede's Avatar
Outdoors
This plywood is A/C
      08-08-2020, 04:47 PM   #11
BimmerDimmer6
Outdoors
This plywood is A/C
I see. Well, personally, I would go with "C" if it was varnished/stained something a bit darker. Looks too plain the wait is now imo. Needs some spice if you will.
      08-08-2020, 07:34 PM   #12
vreihen16
Recovering Perfectionist
vreihen16's Avatar
Drives: 2015 BMW i3 BEV
Personally, I'd lay out today's newspaper on either side, and hit it with several coats of "clear" polyurethane. Every single time that I have ever tried to finish wood, it always ends up with newspaper embedded in the finish. I said that if I were ever doing wood finishing again that I would intentionally seal the newspaper onto the finished surface to save myself some time.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
UncleWede17997.50
wdb4721.50
      08-08-2020, 07:55 PM   #13
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
Both are ugly IMHO.
Burn the A side prior to finishing. Liven it up some.
C the knots just look to machine and not organic.
      08-09-2020, 06:03 AM   #14
Emilime75
Drives: 2010 335i E92 LeMans Blue
Outdoors
This plywood is A/C
A/C, alone, doesn't mean it is suitable for outdoor use. That is just the surface ply "quality" designation, i.e. one side is A grade, while the other is C grade...like what you show in your photos where one side has all of the knots(C) and the other doesn't(A).
For it to be suitable for outdoor use, there need to be additional designations, which vary by manufacturer and will say things like "exterior", "exposure x", "x"...you pretty much have to look up the manufacturer's spec sheet to determine what it is. To take that further, most plywoods that have an exposure rating can only withstand that exposure a limited amount of time before they begin to fail and delaminate.
      08-09-2020, 12:23 PM   #15
Maynard
Drives: 228iX & M2C
I vote side A. They make a marine polyurethane that is VERY durable, but if it isn't true exterior grade it will only be a matter of time. I'd use it on the finished one, either way, since you already have the time into it. But wouldn't sink more time into cutting/sanding more if it isn't exterior grade (looks like it would make nice shelving or other inside uses).
      08-09-2020, 02:09 PM   #16
UncleWede
UncleWede's Avatar
Outside folding table when I take it out of storage. For the day at most. Won't be leaving it out in the elements
      08-09-2020, 03:57 PM   #17
overcoil
Drives: M235i 6spd
Very cool you reclaimed the wood from the particle board top.
Really nice work !
      08-10-2020, 12:27 PM   #18
dtox9
dtox9's Avatar
Drives: '17 X5 F15
I'd say "A" as well....
who knows if the knots on 'c' will eventually start to become uneven or crack.
      08-10-2020, 12:40 PM   #19
UncleWede
UncleWede's Avatar
They have cracks in them now, but I dribbled the varnish in there and filled them up. Will take some future extra sanding to make those spots level with the rest.
      08-10-2020, 05:09 PM   #20
Hawkeye
Hawkeye's Avatar
No_Country
2070
Outdoors
This plywood is A/C
Sounds like it's cool.
      08-10-2020, 05:12 PM   #21
UncleWede
UncleWede's Avatar
Helping, you are not
      08-11-2020, 04:54 PM   #22
Hawkeye
Hawkeye's Avatar
No_Country
2070
I would knot go with the nots. The smooth side looks better and if you want character you can do that with a finish or an insert if you want to put a tad more work in.
