05-23-2019, 03:37 PM | #2 |
636
Rep 3,124
Probably not, but to be safe on how much additional load you're adding, I would couple the mod with an LED replacement.
The power reduction from switching to LEDs will cover the power for the camera and you'll still come out ahead. No bulb-out sensing on the reverse lights.
05-23-2019, 04:17 PM | #3 | |
Rep 2,866
Drives: Anything
05-25-2019, 12:29 PM | #5 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
I tapped the reverse light for my backup camera and it works fine. Although, different cameras may have different power requirements. Which are you going to install?
2008 Z4 3.0si Coupe
06-24-2019, 08:34 PM | #6 |
Rep 3
Relay
I tapped my reverse light power for my backup camera but put a relay in box with the battery. Everything was close and easy. I have been using it for 2 years with no problem.
11-05-2019, 02:39 PM | #8 |
Rep 779
https://www.ebay.com/itm/12V-DC-Car-...5.c10#viTabs_0 like this.. right.. seems easy enough..
-Roranji
