12-29-2019, 02:05 PM | #1 |
Rep 778
License plate led retorfit water issue
Anyone ever use this led instead of the swapping out bulbs ? Curious if there's any weather related issue. I figure for my license plate light rear camera, I can wire up the light to a t10 base and plug it into the factory connectors like how these led lights are setup. Just worry about rain/water
https://www.ebay.com/itm/2-Bulbs-Set...-/302453274675
-Roranji
12-29-2019, 07:39 PM | #2 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
I installed something similar on mine. I even drilled out a hole on one end and installed a backup cam. The LED's super bright and helps illuminate surroundings for the camera. I haven't had any failures or issues due to weather. It's been going strong almost five years now.
What I don't remember is if installing the light was plug-and-play or if I had to do any soldering. It was the least of my problems though, because wiring up the backup cam was the most labor intensive.
2008 Z4 3.0si Coupe
rsutoratosu113.00 |
12-29-2019, 07:59 PM | #3 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
Maybe I’m missing something but why does it matter what bulb or housing you go with when it comes to powering an accessory? Why can’t you swap just bulbs only and tap the same wire that’s in the original housing?
Edit Never mind I see the camera is part of the aftermarket light housing. I thought you said it was rear license [plate] frame. Last edited by 3002 tii; 12-29-2019 at 08:07 PM.. |
rsutoratosu113.00 |
12-30-2019, 09:45 AM | #4 |
Rep 778
I'm only asking because I read a few reviews where the led died.. so either it died because it was cheaply made, ie heat or cheap parts or it died because that connector isn't waterproof and some how water got into the wiring.
Yeah they made the camera integrate into the light, so it looks more oem. My other option was the cut the original light enclosure and screw the camera in and silicone it. Its an option if the led on that camera dies. I have order the t10 pig tail wire, i found some water proof connectors thingy to try.. its coming in a few days ill see if the connector really water poof. I like the bmw setup, when i took the bulb out out, it was definitely water tight.. I dont see any water in there after 10 years..
-Roranji
12-30-2019, 09:58 AM | #5 | |
Rep 12,559
rsutoratosu113.00 |
12-30-2019, 06:15 PM | #7 |
Rep 12,559
And how often are you robbing banks?
12-31-2019, 04:21 PM | #8 |
Rep 778
Quite often.. to pay for this hobby... lol
Going fishing tomorrow... fish the wires out of the bumper and into the trunk.. Reverse led light bar & get that camera installed.
-Roranji
